Dolby advanced audio disappeared from my acer v5 notebook
    I was trying to fix a problem, and then I removed some programs, and I think i accidentally removed a file that is needed for the dolby. Now I canīt open it, and when I try it says that I could re-install it. But how?
    If you have an available System Restore point that is BEFORE whatever you did, that should get it back (the "problem" will also be back after the system restore).
    If you don't have a system restore point (and you should), check the PC vendor's downloads, in this case Acer, and get what you need.
    Windows 8.1 consumer 64 bit
    My acer laptop has a program called "Acer Recovery Management". It allows you to re-install the drivers and applications that came with the PC. I was going to suggest that you look for it on your computer, but when I look at mine the Dolby software is missing. Still might be worth a look see on your computer.
help! Dolby Audio Driver not working after 8.1 update
I updated to 8.1 because supposedly, it was to offer features similar to win 7. Instead, it's even worse than win 8. Now, the sound quality on my laptop is lousy because the Dolby Audio driver receives an error message and isn't working. I went to Lenovo (I have a Ideapad N Series 580) and...
Dolby Advanced Audio Problem after 8.1
I upgraded today to 8.1 and now when I start my computer I get a message box telling me <re-install Dolby advanced audio driver> I found the Dolby program in my control panel, programs and features, and there is no un-installer or, seemingly a way to re-install the driver. I don't want this box...
'Unable to start the Dolby Audio Driver' - (Acer Aspire)
Hi guys, I'm having an (what appears to be quite a common) issue with my sound since installing to Windows 8.1 I have an Acer Aspire V3-571G laptop, and was recently asked to upgrade to Windows 8.1. Once I did that, a pop-up has come up saying:...
Acer 8930g and 5.1 audio problem
Hi, I've installed Win 8 64bit on my Acer Aspire 8930g laptop, in January. Till recently, the 5.1 sound was ok. A couple of weeka ago, the central speaker is silent, the front left & right speakers are very low, the two back speakers and the sub are ok. I tried un-install and re-intall all audio...
Realtek Audio Manager Does Not Show Advanced Settings, Mic
Hello Dear Friends, I have Asus All In One ET2701INKI, the problem is the microphone does not work properly, It has dense distortion and echo, microphone works in other devices very well, I read many topics in many forums and I tried so many things but there is no solution, I am using...
sony z11 audio disappeared from device manager (realtek)
Hey guys, My audio disappeared and stopped working. my audio icon has a red x on it and when i click it it wants to detect problems (it doesn't work). what should i do? how should I diagnose the audio? I feel like this is hardware problem as it just happened out of the blue. The audio...
Drivers & Hardware
my acer 533e notebook is restarting just after displayng the acer log
Hie guys, i bought this acer 5333 notebook and it was running windows 7 perfectly and i installed windows 8 and used it for a week and one day i was repairing windows file and it took long time to finish and i thought it was frozen so i forced it to switch off and the moment i switched on again it...
