How to enable the audio from the external monitor in Win 8
    My laptop is connected to an external monitor by the HDMI cable. The monitor does not have the speakers but has a headphone jack that connects the external PC speakers. The audio, however, is still from the laptop build-in speaker though the video can be seen from the external monitor. I do not know why the audio does not go to the monitor. Can you tell me how to enable the sound from the external monitor instead of the laptop build-in speaks in Windows 8 when the laptop is connected to the monitor by the HDMI? I hope the audio will automatically go to the monitor when it is connected to the laptop but will back to the laptop build-in speakers when the monitor is disconnected. Thank you for your answer.
    compiler welcome to the Eight Forums.
    It is possible that the headphone jack on the monitor requires an analogue connection to the sound card/audio out jack from the computer to the monitor, and doesn't support audio over HDMI to the jack.
    The make and model of the monitor would help.
    I have fixed the problem by entering the Control Panel > Hardware and Sound > Change System Sound > Playback > Click Monitor Name > Set default. The monitor sound is enabled. So, the problem was the sound set in the laptop build-in speakers. However, I wonder whether the laptop can be set to automatically change the sound from between the laptop build-in and monitor speakers when connecting or disconnecting the monitor. It is just like the audio goes to the headphone when it is plugged into the computer. But, the sound will automatically goes to the laptop speakers if the headphone is disconnected.
    Hafnarfjörður IS
    Hi there
    This problem sometimes arises if you are displaying on BOTH monitors -- when you display ONLY on external monitor with the HDMI cable (Win+P to select monitor) the audio will be routed automatically to your monitor from where you can then connect your speakers.
Cannot re-enable disabled RealTek HD Audio
I was having problems reconnecting a bluetooth speaker for my Acer desktop with windows 8.1 OS so tried disabling the default RealTek HD Audio. Now it doesn't show up as a speaker--only my bluetooth speaker that it says is disconnected show. When I look at my device manager it is there, and says...
laptop with two VGA & external monitor
Hello I have a laptop with two VGA (intel & nvidia). I can connect external monitor with HDMI (clone mode), only with intel (from intel's menu). is there any way to connect the external monitor with the nvidia card?
Graphic Cards
New Computer (Win 8.1) Won't Detect External Monitor
Hello, I just bought an HP Envy 23" All-In-One desktop a few months ago and am just now attempting to pair it with an external monitor (TV) via the HDMI port. The computer doesn't even detect that it's been hooked up to anything and the TV still says "no signal". I tried the same HDMI cable...
Graphic Cards
Help with ViaCAD and external monitor
I have a lenovo laptop with 8.1 and a external monitor. When I run ViaCAD I can drag the program to the monitor then the toolbar. Once I close it and reopen it from the monitor the programs opens on the laptop instead. So I have to drag everything over each time I open the program. I've contacted...
Software and Apps
Can't go full screen on external monitor
Hi there, I've just updated my laptop OS from windows 7 to 8 (clean installation) and now I can't go full screen on my external monitor, which is connected via HDMI (23' 1920 x 1080). I'm looking forward for some help. Thanks in advance.
Flickering on external monitor
Hi all, I am currently experiencing flickering on my external monitor, connected via VGA from my laptop--flickering like a low refresh rate even though it is at 60 Hz. I have a Sony Vaio, model vpcsa490x. The laptop has switchable graphics cards and when I switch into the Intel 3000, there is no...
Graphic Cards
