Missing sound system
    I used to have a sound system that ran from my sound card but it doesn't seem to be anywhere, here is what I have under "sound" in Device Manager My system Windows 8 IE10
    I do have sound but its always playing up.
    Regards, iknownuffin70
    Why ever did I purchase a computer.???
    The VIA High Definition Audio looks like your PC's sound device.
    The NVIDIA is for HDMI audio.
    Is the "Speakers" (the VIA HD Audio) set as the default audio playback device?
    missing sound system
    Hi Firebird, Yes they are set as "Default"
    Can you be more specific on exactly what your problem is? If you have the VIA and its set as the default audio playback device the sound should be working.
    missing audio
    I do have audio as mentioned I was just confused that I used to have AC97 which doesn't appear to exist anymore, I was just interested as to why it disappeared.
    Regards iknownuffin70
    AC97 is an old audio chip. With an i5, I would assume you have a current or very recent motherboard that has a newer audio chip and thus the IDT.
    You are right of course Firebird,,,,,As Maxwell smart would say "Why didn't I think of that"
    Windows 7 64bits ?
    Hi Can SOMEONE PLEASE HELP me I have TOSHIBA and My AUDIO worked about a month ago and I am a student I need my Audio to work yet it says my adio is turned off in WINDOWS O_@ I don't understand then it tells me I have no sound device I NEED SOUND Uggg
    PoeticlyMe, please start a new thread, do not hijack someone else's thread.
    Also when you start the new thread, also fill in the "My System Specs" (including your Toshiba model number). That helps us to help you.
Missing sound in speakers after a few videos.
Well this has gone for a few weeks and I had my laptop for about a year now. The problem is after watching 3-4 videos, the sound will not work on the next file. I tried restarting and it worked! But after another 3-4 videos, there was no sound again. Another thing is when I open a music file, it...
Missing System Protection Tab
I have no system protection tab in System Properties box, hence I cannot create a restore point. Looking for the answer to get this tab enabled or reinstalled. I am logging in with Admin rights.
Performance & Maintenance
Missing or glitching System Icons on 8.1
Hello All, I seem to be having an issue with the System UI on Windows 8.1. This is a fresh installation with only a few extras installed. Some select system UI icons have been replaced with rectangles, and is getting to be quite a nuisance. The photos point out only a few of them that show up...
system imaging missing from Windows 8?
I recently purchased an Asus X202E laptop with Windows 8. I immediately did an update for all important/critical Windows updates, but beyond that, I haven't added or changed anything else. When I run the "File Recovery for Windows 7" I do not see the ability to create a system image. I'd like to...
New/Old Surround Sound system
I just got a whole Kenwood VR-209 Surround System with the 15" Woofers, Center Speaker and Rear Sperakers, the 200-Disk CD Changer, Dual Cassette deck and everything that came with it, for a very good low price. So, I plugged my HDTV into the "Video 2" Dolby Digital/PCM using an RCA Coax Cable -...
Windows 8 missing program event in sound tab
I just bought a new windows 8 tablet recently and I have tried to download few alarm clocks from the store. The problem is each apps which I have tried can't change the alarm sound. The apps itself can browse and change the sound file without errors but when the alarm hit the time, the alarm will...
Power icon missing in system tray.
Not sure if I should post it in Performance forum. I have a Acer Aspire 7741Z laptop. Guest OS ....... Win 8 RP in VMware player. Host OS ........ Win 7 Home Premium SP1. Issue.... Power icon is missing in the system tray. When I went to Customize > Turn System Icons On or Off > The...
