Windows 8 Forums
Results 1 to 4 of 4
Thread: Sound Problem
    Junior Member
    Sound Problem
    Hello
    i have a problem in the sound In w8
    when i start the computer after a shut down, the sound doesn't work
    but if i restart the computer it works fine,
    it means every time i have to restart to have the sound working
    any idea?
    zigzag3143's Avatar
    Wanikiya & Dyami
    Array
    WCP
    Micronesia
    Quote Originally Posted by ARDV View Post
    Hello
    any idea?
    Probably a driver, have you checked device manager to see if it is installed and working?
    Please go to start > search > type device manager.
    Check for any "unknown devices" (with yellow triangles on them)
    Is you driver there, listed, and working?
    If your driver is missing, or there is a yellow triangle on it, you will need to update it.
    How To Find Drivers:
    - search Google for the name of the driver
    - compare the Google results with what's installed on your system to figure out which device/program it belongs to
    - visit the web site of the manufacturer of the hardware/program to get the latest drivers (DON'T use Windows Update or the Update driver function of Device Manager).
    - if there are difficulties in locating them, post back with questions and someone will try and help you locate the appropriate program.
    - - The most common drivers are listed on this page: Driver Reference Driver Reference
    - - Driver manufacturer links are on this page: Drivers and Downloads
    Junior Member
    I'm sure the driver is up do date
    i used lot of driver programs like: Driver pack solution,
    the problem is just in the first start, when restarting the sound works correctly
    in the first start, when i click the sound icon, the sound device is not shown
    Junior Member
    well, i searched again and i find this
    ECS Web Site
    my motherboard model is that one
    i used compatibility mode to install the driver
    but, like always, when shutting down and starting and going to device manager, i don't find the driver listed
    and i just find: usb headset
    and the sound doesn't work
I want an awesome startup sound! Chillout Room
Sound drivers for Dell Dimension 8400? Sound & Audio
No Sound from X-FI Xtreme Gamer Sound & Audio
.net 3.0 problem Installation & Setup
Is there a problem with SF??? Chillout Room
