8.1 sound problems
desdem12
Updated to 8.1 and had the dolby problem like everyone. I am not that good with these new fangled machines but how do I fix this problem. The sound is now terrible and I have it all the way to the top and can barely hear anything. Is there a fix that is available or do I need to go back to regular 8 and if so how do I do that. Thanks.
Is a Lenovo laptop.
    windows 8.1
welcome to the forums mate.
First off, you'll need to let us know what kind of laptop you have (so we can direct you to the correct driver). You may need to simply update the drivers for it, to the newest 8.1 audio drivers. Check windows update for any other fixes - that may also help.
    Windows 8.1 Pro with Media Center x64
    Custom
    Intel Core i7-3820 CPU OC @ 3.80GHz
    Gigabyte G1.Assassin2
    Corsair Dominator 16GB Quad Channel DDR3
    Nvidia by EVGA - GeForce GTX 670 4GB
    On board Creative SB X-Fi
    acer 24" H243H
    1920 X 1080
    Main 500GB Hybrid Drive @ 7,200RPM
    Secondary OCZ SSD Vertex 3 Max IOPS
    Silent Pro 1000w gold 80+
    Azza Hurrican 2000
    Liquid CPU cooler & fans
    Microsoft Comfort Curve 2000
    Tek Republic Wired Laser Mouse
    5ms Ping 5.15Mb/s Download .64Mb/s Upload
    Internet Explorer
    Defender, Malwarebytes
Thanks for that. I am not sure how to tell what it is. Has an intel core I3. I will try the window update. I not a very good techy but I try anyway lol.
    windows 8.1
Is a Lenovo laptop.
If you provide your Lenovo specific make/model number, someone can help you find the correct drivers.
    Intel G2020
    ASRock B75M-DGS R2.0
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
Ok I found the box.
2.5G
4G ram
Lenovo G580
model name 20150. IF you need something else I can probly find it.
    windows 8.1
I think it is related to the dolby problem as I still get that message when I start up in the morning or after restart. I found the dolby program in the programs list and tried "repair" a few times but it didn't help.
    windows 8.1
Ok I found the box.
2.5G
4G ram
Lenovo G580
I have to go out for a bit but someone should be able to help you now.
Good luck,
my2cents
    Intel G2020
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
All righty, that's perfect. This is the audio driver for your Lenovo G580 computer (clicking the link will ask to download the driver): http://download.lenovo.com/consumer/mobiles/au200w81.exe
it is for the Conexant Audio Driver for Windows 8.1(32-bit OR 64-bit) - IdeaPad G480 lenovo
    Custom
    acer 24" H243H
    1920 X 1080
    Azza Hurrican 2000
    Internet Explorer
You're welcome. Did it work? Any more problems?
You may need to update all the drivers (because down the road they all might give you problems). Lenovo makes spotting the correct driver very difficult. You might see if you can go to the support page of the Lenovo website and download a driver detection tool, if the offer it.
    Custom
    acer 24" H243H
    1920 X 1080
    Azza Hurrican 2000
    Internet Explorer
I checked lenovos sight and they had nothing on it. I did see a detection tool though somewhere. I haven't tried it yet
    windows 8.1
Might help you out with the other stuff. Good luck mate,
Take Care
    Custom
    acer 24" H243H
    1920 X 1080
    Azza Hurrican 2000
    Internet Explorer
