Solved Realtek HD Audio device driver
Kynix
Am I int the right place?
Helsinki
Thanks for anyone, who helps me :D
I have "an old fashion motherboard,, with realtek's VT1818S High Definition Audio 8-Channel soundcard build in to the Asus m4a77 motherboard. Usually with W7 windows i had to install the driver from asus's website... so far when i get to the installation point it says:
none of this package's drivers are compatible with your pc
allthough, this time W8 did install the driver but its delivered by microsoft, High Definition Audio device. well... the card works, if i keep the speakers attachde to the front jack. and the stereo mix capturing doesn't work.
Any help?
    Windows 7 x64 Home Premium / Commodore OS Vision / Windows 8 Release preview
    AMD Athlon x2 Dual Core 7750 BE 2,7Ghz (2/4)
    Asus M2N-e
    4Gb
    GIGABYTE (ATI) Radeon HD 6870 (1Gb)
    Do i have one?
    1x HD1080 1x SXGA
    1x Samsung 500 Gb
    1x Samsung 30 Gb
    1x LaCie 1Tb Hard drive.
    Antec 500W
    Antec three hundred
    3 fans + psu and cpu + gpu
    Logitech G19
    CM Storm Xornet
    110mb/ s
    Look, what i've created... just a few visits at the recyclement center was enough...
Try running in compat mode. Steps 1,2,3 of option one should get you there. You may need to ininstall what you have going then run this on the exe that you downloaded from asus.. good luck to you
Compatibility Mode - Windows 7 Forums
    WDP 8 x86
    Dell Lat 530 Lappy
    Dual Core
    24 Mbps sometimes high speed cable
    Asus M2N-e
    4Gb
    Do i have one?
    1x HD1080 1x SXGA
    1x Samsung 500 Gb
    1x Samsung 30 Gb
    Antec 500W
    Antec three hundred
    Logitech G19
    CM Storm Xornet
    110mb/ s
I have a Realtek sound card (HD) that worked both front and back audio ports worked in Vista, but in both 7 and 8 the front doesn't work. I have attempted to install proprietary drivers in all valid comp. modes with no success, any thoughts
    Windows 8 Consumer Preview amd64
    Custom
    AMD Athlon 4200+ Dual Core
    PCCHIPS A15G v1.0
    2 GB DDR 2 800
    nVIDIA 8800 GT Ultra 512
haha PCChips - that was the maker of my motherboard until it blew the caps and I replaced it for 30 U.S.D. to my door with the one in specs.
You have Realtek ALC662 - the latest driver should work well for you - Realtek HD Audio 2.68 audio driver download from Guru3D.com
If you still have the issue, check your bios for any settings that may be affecting it and you can then also check the Realtek Sound Manager and/or other software included in the driver setup.
Here's another resource you might use if you still have to try new things for some reason:
REALTEK - Download driver for your Realtek sound, Realtek network and Realtek wireless or wifi card for Microsoft Windows
I highly do not recommend this, but if you can't sort it out with the above, then you can install the very old one from your motherboard page using the device manager.
If you have bsod issues after doing this, look to it as the culprit.
    P4 3.4 GHz HT
    MSI-7211
    OCZ 2 GB DDR @ 400 MHz
    HIS AGP HD 3850 Turbo Ice-Q
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Funny thing though: Just yesterday, for the heck of it (I don't even use my onboard Realtek, although it is good) - I was reviewing the Realtek codecs' spec reference designs and schematics. I like learning about things.
While I didn't check each and every last one, it seems as though all the Realtek codecs support the case ports by default. Meaning - the latest driver should enable that for you one way or another, even if you have to play with settings here or there as stated above.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
