Dolby Advanced Audio Problem after 8.1
    I upgraded today to 8.1 and now when I start my computer I get a message box telling me <re-install Dolby advanced audio driver> I found the Dolby program in my control panel, programs and features, and there is no un-installer or, seemingly a way to re-install the driver. I don't want this box popping up at every boot, what do I do?
    I don't have Dolby specific setup, but you might want to check your device manager directly to see if a driver for Dolby appears under the expanded menu as shown below. If so, you can select "update driver" and have it automatically search Window Update or use the latest driver (if you have it handy). I would personally prefer the latter option if available. Good luck.
    You re-install the driver by going to your motherboards website and downloading a new version of the driver and installing it.
    United States
    Windows 8.1 Pro 64-bit
    In my Acer Recovery management there is an option to re-install drivers.
    Acer Aspire v3-571g - Windows 8.1 Audio Driver.. dolby home theater v4 does not work at all.
    Lenovo G780 - on windows 8.1 problem is the same. After recovery function Dolby advanc.. v2 run´s normal.
    After removing driver, restart, installing new driver, restart, still the same
    Purpose, it´s the Windows 8 version 8.1. The 8.1 is not possible running the Dolby....v2.
    Maybe after buying the soft, i do ( apologize myself ) think the Dolby soft will not run.
    I see the problem in software disfuncionality somewhere in Win 8.1.
    Still it has nice colored boxe´s eh?
    I have tried something else, but it is not as good as having dolby audio around. It's playing on headset, not on speaker.
    Finaly here we have the solving problem solution:
    You must uninstall your current audio driver and replace with the newest driver. Beware who the manufacture is.
    In my case i have the Conexant audio HD driver.
    Do not forget to uninstall the Dolby software too.
    In my case i have Dolby Advanced Audio V2.
    then go to : , that´s the Conexant,
    and : , that´s the Dolby soft.
    Download them.
    In simple step´s:
    1. Uninstall the audio driver ( in device manager search for audio driver - look after the speaker icon )
    DO NOT Uninstall the the speaker driver - it is difference, because ( in my case I have ) there are 2 driver´s
    making the basic audio work. First is the audio driver for software solution, and speaker driver for speaker solution
    Maybe some PC´s have one or two drivers for the audio. btw.
    2. Restart
    3. Uninstall the Dolby Adv....
    4. Restart
    5. Install the new Conexant audio driver from web above
    6. Restart
    7. Install the Dolby Adv.... driver from web above
    8. Restart
    9. Enjoy
    For those who are live sensitive from detail´s : the joke
    Windows 8 has writen that the version of Conexant has no need to upgrade the driver ( ) on the support site is version ( hint )
    Quote Originally Posted by kmoss View Post
    I have tries something else, but it is not as good as having dolby audio around.
    Just uninstall the software you mentioned. Take a look for newest driver´s form your pc manufacturer.
    I don't know how to install it.
    Wish I do. I have completely uninstall the Conexant audio HD driver.. I can't find it anymore. Wish t'was easy as downloading this Windows 8.1 on windows store.
Page 1 of 2 12 LastLast
help! Dolby Audio Driver not working after 8.1 update
I updated to 8.1 because supposedly, it was to offer features similar to win 7. Instead, it's even worse than win 8. Now, the sound quality on my laptop is lousy because the Dolby Audio driver receives an error message and isn't working. I went to Lenovo (I have a Ideapad N Series 580) and...
'Unable to start the Dolby Audio Driver' - (Acer Aspire)
Hi guys, I'm having an (what appears to be quite a common) issue with my sound since installing to Windows 8.1 I have an Acer Aspire V3-571G laptop, and was recently asked to upgrade to Windows 8.1. Once I did that, a pop-up has come up saying:...
Nvidia HD audio and Microsoft hd audio Driver problem
Realtek Audio Manager Does Not Show Advanced Settings, Mic
Hello Dear Friends, I have Asus All In One ET2701INKI, the problem is the microphone does not work properly, It has dense distortion and echo, microphone works in other devices very well, I read many topics in many forums and I tried so many things but there is no solution, I am using...
Dolby advanced audio disappeared from my acer v5 notebook
I was trying to fix a problem, and then I removed some programs, and I think i accidentally removed a file that is needed for the dolby. Now I can´t open it, and when I try it says that I could re-install it. But how?
Lost my Dolby sound in win 8
My win 8 package comes stock with Dolby advanced audio. I uninstalled the IDT driver and its software from device manager to roll back to an earlier version to solve a problem.. that didnt work, so i reinstalled the original drivers and it's software as both downloaded from hHP ( see me specs) and...
Drivers & Hardware
audio problem in win 8
i have acer laptop v5 431 ,, the audio is dolby advance but after some time the audio quality has gone down and it does not feel like dolby anymore .plz help me . i have reinstalled drivers and windows says that there is some problem and the anhancements need to be disabled .. after disabling...
