Front Audio panel not working on Windows 8.1
SlimShady
I have a Gigabyte GA-F2A75m-HD2 (Rev 1.0) board and this is quite an odd one. The front port worked with Ubuntu and other Linux distros but it seems to be the opposite case with Windows 8.1. I installed the latest Gigabyte version of the Realtek HD Audio Manager but it still doesn't work. What should I do?
I have the codec ALC887
    Windows 8.1 64-Bit
    Gigabyte
    AMD A4-5300 3.4 GHz
    Gigabyte GA-F2A75M-HD2
    4 GB
    AMD Radeon HD 7480D
    Realtek HD Audio ALC887
    Samsung SyncMaster S16A100N
    1366 x 768
    Seagate 80 GB
    500 Watts
    Astone Enforcer
    AMD Stock
    Logitech
    Logitech
    1.0 MBPS
    Mozilla Firefox/Google Chrome
    Avast/ESET/Comodo
You might want to double check if you have the latest BIOS firmware.
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
Is the device listed in the device manager?
If not, you can check the Bios to see if it's still enabled.
    Self built
    Intel Core i7-4790
    GA-Z87X-D3H
    G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNT
    Sapphire ATI Radeon R7 250
    Realtek ALC892
    Samsung UN32EH5000, Dell 1703FPT
    WD5003AZEX
    WD10EZEX
    Samsung HD103SJ
    Samsung 128 GB 840 PRO
    SeaSonic M12II SS-500GM
    Fractal Design Define R4
    Zalman CNPS9900ALED
    Logitech K800
    Logitech M705
    16 Mbps
    Avast
    Bose Companion 2 Multimedia Speakers
Oh so I need the latest BIOS version for it to work then aye? Okay I'll try.
    Windows 8.1 64-Bit
    Gigabyte
    AMD A4-5300 3.4 GHz
    4 GB
    AMD Radeon HD 7480D
    1366 x 768
    Seagate 80 GB
    500 Watts
    Astone Enforcer
    AMD Stock
    Logitech
    Logitech
    1.0 MBPS
    Avast/ESET/Comodo
First, check to see if the HD audio is enabled in the bios.
    Self built
    Intel Core i7-4790
    GA-Z87X-D3H
    Realtek ALC892
    WD5003AZEX
    WD10EZEX
    Samsung HD103SJ
    Zalman CNPS9900ALED
    Logitech K800
    Logitech M705
    16 Mbps
    Avast
It just detects the rear sound card. As far as I know the front port uses the AC'97 version of the board that the case originally came with.
    Windows 8.1 64-Bit
    Gigabyte
    AMD A4-5300 3.4 GHz
    4 GB
    AMD Radeon HD 7480D
    1366 x 768
    Seagate 80 GB
    500 Watts
    Astone Enforcer
    AMD Stock
    Logitech
    Logitech
    1.0 MBPS
    Avast/ESET/Comodo
    Self built
    Intel Core i7-4790
    GA-Z87X-D3H
    Realtek ALC892
    WD5003AZEX
    WD10EZEX
    Samsung HD103SJ
    Zalman CNPS9900ALED
    Logitech K800
    Logitech M705
    16 Mbps
    Avast
    Windows 8.1 64-Bit
    Gigabyte
    AMD A4-5300 3.4 GHz
    4 GB
    AMD Radeon HD 7480D
    1366 x 768
    Seagate 80 GB
    500 Watts
    Astone Enforcer
    AMD Stock
    Logitech
    Logitech
    1.0 MBPS
    Avast/ESET/Comodo
What's showing in your device manager?
Screenshots and Files - Upload and Post in Seven Forums - Windows 7 Help Forums
    Self built
    Intel Core i7-4790
    GA-Z87X-D3H
    Realtek ALC892
    WD5003AZEX
    WD10EZEX
    Samsung HD103SJ
    Zalman CNPS9900ALED
    Logitech K800
    Logitech M705
    16 Mbps
    Avast
    Windows 8.1 64-Bit
    Gigabyte
    AMD A4-5300 3.4 GHz
    4 GB
    AMD Radeon HD 7480D
    1366 x 768
    Seagate 80 GB
    500 Watts
    Astone Enforcer
    AMD Stock
    Logitech
    Logitech
    1.0 MBPS
    Avast/ESET/Comodo
Two things you can check.
1. Enabled
2. Front Panel Levels
    Self built
    Intel Core i7-4790
    GA-Z87X-D3H
    Realtek ALC892
    WD5003AZEX
    WD10EZEX
    Samsung HD103SJ
    Zalman CNPS9900ALED
    Logitech K800
    Logitech M705
    16 Mbps
    Avast
It didn't work.
    Windows 8.1 64-Bit
    Gigabyte
    AMD A4-5300 3.4 GHz
    4 GB
    AMD Radeon HD 7480D
    1366 x 768
    Seagate 80 GB
    500 Watts
    Astone Enforcer
    AMD Stock
    Logitech
    Logitech
    1.0 MBPS
    Avast/ESET/Comodo
    Self built
    Intel Core i7-4790
    GA-Z87X-D3H
    Realtek ALC892
    WD5003AZEX
    WD10EZEX
    Samsung HD103SJ
    Zalman CNPS9900ALED
    Logitech K800
    Logitech M705
    16 Mbps
    Avast
Does that mean that I would have to remove the Realtek Audio HD Manager?
    Windows 8.1 64-Bit
    Gigabyte
    AMD A4-5300 3.4 GHz
    4 GB
    AMD Radeon HD 7480D
    1366 x 768
    Seagate 80 GB
    500 Watts
    Astone Enforcer
    AMD Stock
    Logitech
    Logitech
    1.0 MBPS
    Avast/ESET/Comodo
It didn't work.
    Windows 8.1 64-Bit
    Gigabyte
    AMD A4-5300 3.4 GHz
    4 GB
    AMD Radeon HD 7480D
    1366 x 768
    Seagate 80 GB
    500 Watts
    Astone Enforcer
    AMD Stock
    Logitech
    Logitech
    1.0 MBPS
    Avast/ESET/Comodo
Mr. S. and others have been doing a fine job of supporting you throughout this issue so there is very little for me to suggest; however, I did notice you installed that Realtek Audio Manager and I also noticed that your front panel headset option is not displaying either. That tells me that something may have come "coincidentally" loose inside your case. So, have you opened the case to ensure all connections to the front panel header are still secure? If so, I would tentatively recommend that you try uninstalling the Realtek Audio Manager and see if that fixes your issue because I also have the same chipset that could benefit from the R2.71 drivers; however, I decided not to install it because my audio worked perfectly (both front and back) with the drivers found during my Windows 8.1 Pro installation. Here's my screen for comparison:
Good luck.
    Intel G2020
    ASRock B75M-DGS R2.0
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
I just checked and the cable sits stable on the board :)
    Windows 8.1 64-Bit
    Gigabyte
    AMD A4-5300 3.4 GHz
    4 GB
    AMD Radeon HD 7480D
    1366 x 768
    Seagate 80 GB
    500 Watts
    Astone Enforcer
    AMD Stock
    Logitech
    Logitech
    1.0 MBPS
    Avast/ESET/Comodo
OK, just wanted to be sure. Did you try uninstalling the Realtek Audio Manager completely and rebooting to see if your headset port is now being detected?
    Intel G2020
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
One more thought, if you trying to configure 7.1-channel audio, you have to use an HD front panel audio module and enable the multi-channel audio feature through the audio driver. However, if you are using anything less, then maybe you need to set that option to either 5.1 or just stereo (eg two speakers) to see if the front panel ports are now recognized as such.
    Intel G2020
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
I am not sure if this is correct. Normally, there are 2 connectors: AC'97 and HD Audio on the cable for front panel audio. I use the HD Audio Connector for all my PC's so you might want to double check the MB manual whether HD Audio Connector should be used instead.
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
