How to remap the volume keys Help Please!!
    Windows 8 64 bit
    I cannot stand having to hold the "Function" key plus the volume up F12 or down F11. I want to remap some keys to be a direct volume up and volume down. Thank you for the help!
    Some laptops have the capability to make the FN key a sticky key; whereby, you would only have to press that once and then you could toggle between F11 and F12 as needed. Also, some laptops have an Instant Key function that may work for you:
    San Jose - California
    If your laptop does not have the features that My2Cents suggested. You can use Autohotkey to remap: AutoHotkey
    Below is a post that I helped this person with a broken PrintScreen key and he has to remap the key to something else:
Volume Keys stopped working
I have a Toshiba Satillite laptop running Windows 8 which I use for storing, recording and playing back music. Everything worked fine until a few weeks ago when the volume keys on the keyboard stopped working. I still get sound at whatever level is set and I can adjust the volume if I access the...
Mic volume too low
Hey is there any way to increase the mic volume besides the one in the controll panal thing? I maxed everything out but it's still not enough ;(...
remap meta + hjkl keys to arrow keys.
Hello, I am used to using the hjkl keys as arrow keys on my home computer by using xmodmap to avoid moving from the home row. Is there any way on 'microsoft windows 8' to configure the hjkl keys to be used as arrow keys while a modifier key such as 'ctrl', 'alt' or 'meta' is held down? The hjkl...
Volume mixer becomes unresponsive when I change volume
Scanning and repairing volume (\\?\Volume...) on startup
Hello Guys, this is my first post on eightforums, i recently got a new laptop "asus vivobook" that came preloaded with windows 8. The laptop comes with a hybrid 24 GB ssd (8GB of those are for the system files,windows 8 is installed on,the remaining are in a 2nd partition for recovery) i...
Performance & Maintenance
Volume keys
I have a toshiba satellite C855 with windows 8. I used to be able to use my function keys without using fu, but now I have to. Please help me change it back to the way it was.
remap keyboard keys
hi, please help my escape key is not working i want to remap my keys please help
