I have a Genius150 watt 5.1 speaker system Genius
I dont have the realtek driver installed since the sound quality was not satisfying with it so I stayed to the default high definition audio device with stereo configuration.
I have an integrated sound card. This is my motherboard model GIGABYTE - Motherboard - Socket 1155 - GA-P61-S3 (rev. 2.0)
I want to know what sample rate and bit depth to choose for best quality playback at advanced speaker properties? The default ones are 16 bit , 44100 cd quality like you can see in the below image
I dont understand what is that shared mode either.
If I install again the realtek driver what should I choose then ?
- Windows 8 64 bits
- CPU
- Intel® Core™ i5-3350P Processor (6M Cache, up to 3.30 GHz)
- Motherboard
- Gigabyte Intel Socket 1155 P-61-S3/rev 2.0
- Memory
- 4 gb ddr3
- Graphics Card(s)
- Gigabyte GeForce gtx 660 OC 2GB
- Monitor(s) Displays
- Packard Bell Maestro 220Wdv
- Screen Resolution
- 1680X1050
