Metro IE youtube no sound
    Windows 8 32bits
    When I play a video in metro ie no sound could be heard but yesterday there was (hibernation)
    The beggining of the problem was that I had one video opened with sound then paused it opened in new tab second video with no sound while in the first there still was
    So far i restarted the computer and reinsalled adobe flash player googled a lot and not found anything.
    I was looking for a way to reinstall metro ie but that didn`t work as well(no info) but even though i can uninstall it.
    Thank you for your time.
    Your issue is probably not the same as my fiasco with "no YouTube sound" but just to make sure, I will point you to 4WDs suggestion that helped me fix mine (see post #2):
    Flash Update Killed My Youtube Audio on 2 Different PCs
    Good luck.
No Sound with Youtube videos
All at once I am not able to get sound from YouTube files on websites or YouTube. On websites I get video and sound as long the file is not a YouTube file. I have tried IE10 and Firefox and still no luck. Adobe Flash plug-in is enabled and I know the sound card is working.
How to fix no sound in Chrome for YouTube
When viewing flash player videos from YouTube and/or similar sites, no sound can be heard. To fix this issue follow these steps: In a new tab, go to chrome://plugins Click on +Details
No sound in metro/modern apps
I've got a very strange issue which I can't see anywhere else on this site. Basically sound works perfectly fine in the desktop and all legacy apps however there is no sound at all in any metro apps. Skype/ IE 10/ Xbox music/ games all have no sound. My sound in all apps (modern and legacy) has...
Metro IE10 not rendering embed youtube
Is there something I have to do to enable it or is it something that doesn't work yet? If I hit to view on desktop they appear fine on IE10, but not inside metro.
Browsers & Mail
Upload to youtube directly from metro?
Since this is a mobile os... how can you upload a video from the metro interface to youtube? Just like you would with an iphone with simple taps? Thanks
Software and Apps
Youtube in IE10 Metro?
Is there some way to get this working? I have it set to HTML5, but it says it does not recognise any video formats.
Browsers & Mail
