Volume is set at a certain level
    My new laptop seems hardwired to think that if I set the volume to 20, so long as I have headphones in, I want my volume at 20 for all sounds, ever. This makes music which varies from quiet and loud feel extremely alien and even ruins the feel of some videos and games. But it's most notable when watching a youtube video and I change the volume. Turning it up makes the video louder for a split second before returning to what it was, turning it down? Well, that works for a few seconds and returns to being too loud.
    My new laptop uses HP Beats Audio. While I'm currently blaming Windows 8 for this problem, it'd be silly not to mention it. Unfortunately, a google search didn't get me any answer for beats either except how to uninstall it.
    This doesn't happen on my old Laptop, which runs Windows 7 and appears to lack a special audio device. Looking online for a fix has only returned me nonsense about Windows 8 reducing volume for communications devices (a feature which I have off). In my search, I found this bit of information from
    "Incidentally, Windows 8ís new Metro-style volume controls lack many of the more sophisticated controls that are available via the desktop. Thereís no way to control the volume of individual Metro-style apps, for example, and thatís true of both the new Metro volume controls and the legacy desktop interfaces. Instead, the system automatically controls app volume, muting or lowering the volume of background apps when needed."
    So... I suppose in short what I need to know is, how do I turn this "feature" off?
    I don't recall seeing another post about this specific problem, although I have not looked at every post on this forum, thus I would consider it a problem in the PC, not Windows 8.
    I have seen several problems with the Beats Audio, which is an "enhancement" to the audio chip that is being used.
    You can try temporarily disabling the Beats Audio and see if that makes a difference. Otherwise with a new PC, which should be in warranty, I would contact HP support (or take it back for an exchange if you bought it locally and have a return option).
WHEA_Uncorrectable BSOD, regardless of PC's activity level
Hi all, I am having an issue with the pc I built a few months ago. It doesn't seem to matter how I'm using the PC or what programs I'm running, I keep getting a WHEA_Uncorrectable error followed by a shut down and restart. I have checked and rechecked my drivers, and I canít figure out...
BSOD Crashes and Debugging
Interoperable Top Level Domain Name Parsing comes to IE
Windows 8 News
Adjust Sound Level?
Everytime I depressed the volume up/down key on my keyboard, it raises the volume in windows by 6%. Is there anyway to modify this? For example I would like the volume to rise or lower by only 3% everytime I depress the volume control button on my keyboard. I have messed around with the settings...
Windows Phone 8 Volume Level - Adjust
How to Adjust Volume Levels in Windows Phone 8 and 8.1 This tutorial will show you how to adjust the volume level settings of items up and down to what you want in Windows Phone 8 and 8.1. Adjust Volume Level Settings in Windows Phone 8 1. Press the volume up + or volume down - button....
Volume mixer becomes unresponsive when I change volume
Scanning and repairing volume (\\?\Volume...) on startup
Hello Guys, this is my first post on eightforums, i recently got a new laptop "asus vivobook" that came preloaded with windows 8. The laptop comes with a hybrid 24 GB ssd (8GB of those are for the system files,windows 8 is installed on,the remaining are in a 2nd partition for recovery) i...
Performance & Maintenance
Browser default zoom level
My IE browser opens at 150% zoom after I change it to 125%. How to make the 125% setting stay put?
Browsers & Mail
