Volume Keys stopped working
  1. #11
    Volume keys stopped working
    Yes that's why I copied the whole message from Toshiba. In my case it didn't matter as the computer is quite new and I only use it for music. I didn't loose any of my documents or music files only the programs I'd downloaded and it was just a few minutes to download them again. I also had to get rid of that wretched Mc Afee again and restart Windows Defender.
    I still don't know how the setting came to be changed so I've got my fingers crossed it doesn't happen again.
    Thanks for your help.
  2. #12
    Win 8
    I had to hit num lock a couple times to get mine to work. A-ok now. What a pain in the butt to find the answer.
  3. #13
    windows 8.1 upgraded to 10
    I found that going to device manager and updating the hot key resolved my keyboard issues.
Page 2 of 2 FirstFirst 12
Certain Keys have stopped working . Please help.
Hello recently the following keys have stopped responding . :rolleyes: 0 p : Up arrow [ - and ? Please help , thanks in advance . I will a Keyboard USB tomorrow and i am using On Screen keyboard atm I game so it will be a issue in the future .
Performance & Maintenance
Laptop Keys Stopped working - Lenovo Ideapad Z500 Win8
Hi Guys, I am a member of the sevenforums and currently have a win8 laptop so thought I'd sign up here (seems to be the same people behind both forums). I'm having a little trouble and would really appreciate some feedback. My Lenovo ideapad z500 had 2 keys (K and I) that stopped working...
W8 hot keys have stopped appearing
For the past few days my hot keys have disappeared. I haven't changed any settings or installed anything. How do I get them back?
IE 10 stopped Working error / Search engine not working
Hi! I am repeatedly getting the error "Internet Explorer not working" / Windows checking for solution/Last browsing closed unexpectedly , then Restore Session. I went to google to find a fix for this error .I'm being told to Press Window + W key then type in Troubleshooting in the Search box , then...
Browsers & Mail
Some Keyboard keys not working / working incorrectly
Hi, I updated my Synapse software (Razer) and suddenly my BlackWidow mechanical keyboard isn't working fully. The F keys are not working correctly the F10 mutes and F11/12 turn the volume up and down (almost like it's a laptop keyboard). The Windows key has swapped with the ALT key and also the...
Drivers & Hardware
How to remap the volume keys Help Please!!
I cannot stand having to hold the "Function" key plus the volume up F12 or down F11. I want to remap some keys to be a direct volume up and volume down. Thank you for the help!
Volume keys
I have a toshiba satellite C855 with windows 8. I used to be able to use my function keys without using fu, but now I have to. Please help me change it back to the way it was.
