My stereo mix doesn't work well
    Title: My stereo mix doesn't work well
    My PC: SP 2000-2b49Ca, window8
    Audio: Realtek driver: (installed sept 21 2013)
    Panel settings:
    External Mic: ready, level 75+20dB, 3,5mm connector
    Microphone: ready, level 75+20dB, ATAPI internal connector
    Stereo mix: default, level 75, no connector info (???)
    My recording setup:
    1) Quicktime to play a short instrumental
    2) Audacity to record it and add my voice using a mic
    My problem when recording: (one shot: music + my voice)
    1) input device: stereo mix
    Playback result: music only, no voice
    2) input device: Ext. Mic or Microphone (I tried both)
    Playback result: my voice only, no music
    With Ext. Mic the sound is lower than with Microphone (same setting)
    I also noticed when playback: skipping and buzz sounds.
    With my old PC(XP, sound blaster) everything was working fine.
    Input device: what you hear (with a mic ready)
    Playback result: music and voice (very good)
    I am a songwriter and I need a PC that can do what I want:
    Record my music with my voice. As simple as that.
    Any solution?
    Thanks, Guy
    I have a recording studio (I use Sonar X2 DAW software). Your best option is to buy a small USB connected recording interface unit. It will work better than any PC audio device and have less latency than the PC audio does. It will also allow you to use better quality microphones, such as a Shure SM58.
    A device such as the Focusrite Scarlet 2i2 would work well. I think it even comes with a recording program.
    Focusrite Scarlett 2i2 |
Downloading 8.1 doesn work
I keep getting a message to download 8.1 but I click to d/l and it tells me I can keep on working and it will let me know what to do next..... nothing happens. Tried twice.
Performance & Maintenance
My product key doesn't work
Hi! I've bought Windows 8 when it was first released, but reinstalled Windows 7 again. Now I want to install Windows 8.1, but I get an error saying my product key is invalid. I've tried multiple product keys (We own multiple computers, two of which have Win8 installed), but I get the same error...
Installation & Setup
Windows 8 Doesn't work! Please Help!
Okay here's the thing, my computer worked fine and all but one day i turned the computer off and now i can't get in to windows.. let me explain When i start my computer everything works fine until the windows logo shows up it's loading but never finishes. after a while it gets BSOD for like a...
BSOD Crashes and Debugging
GPU Sometimes Doesn't Work
Hey all, Not sure where to post this so thought I would try here. Ever since I've put together my new PC I have had an issue with my wireless card. Sometimes when I start up my PC the driver doesn't load for it, I can see it in the device manager list but the driver hasn't loaded and when I...
Graphic Cards
My Windows Key doesn't work
I had been using the Windows key to switch back and forth from Metro to desktop. When I am in Metro, pressing it does nothing, but it works everywhere else. I simply click on the desktop icon, so it's no big deal, but is there a solution?
WIN + Tab doesn't work but ALT + Tab does
WIN + Tab doesn't work but ALT + Tab does Has anyone else observed this?
