Optical Splitter
    Optical Splitter
    I have a splitter that connects my XBOX360 and my Windows 8 desktop computer to my amplifier. However, when I have both my XBOX and Computer on, the sound does not work.
    The solution is that I turn off my computer whenever I want to use the Xbox. This fixes the problem because it turns off the light of the digital output.
    Is there a way for me to turn off the digital output light without actually turning off the computer?
    Did you try just muting the sound in the PC ? If that doesn't work maybe you can temporarily disable Digital sound from Control Panel /Sounds /Playback.
Optical Splitter
Do I need a splitter?
Hello, I'm thinking of buying an in-ear earphones, Roccat Syva, it has a built-in microphone but the cable is in on one combined jack, not separated for audio and mic. My laptop has only one jack, audio and mic combined, so will the microphone works? Or do I need a splitter cable for the...
USB optical mouse not working!
I have dell inspiron 15r 5537 and is running on windows 8. This morning I updated windows and my optical mouse stopped working after that. The touchpad is still working.The device manager>HID complaint mouse has status Can anyone please help me solving this?? additional info:...
Drivers & Hardware
Blu-ray Optical to TV/Xbox 360
Is it possible? THAT is the real question.. I've been researching a ton online and can't seem to find anything that I can get that will allow this. I have Windows 8.1 OEM and I can stream any video I want that's already downloaded to my computer using the video app and my xbox 360's use of Play...
Drivers & Hardware
New computer no optical drive can I put app on SD USB
I just bought a new Windows 8 computer that doesn't have an optical drive. I need to install Adobe CS3 and Office 2003 on my computer. Both are on disks, can I put them on USB or SD to instal. Len
optical drive not working
ok the optical drive on my laptop hasnt worked for about a year now... in the beginning it went out and i used the upper and lower filters fix and it worked. then it went away again and it still hasn't shown back up. it doesn't show in bios or disk management or anything. im not really sure how...
Drivers & Hardware
mp3 splitter
Hello Everybody, I've been using w8 for a couple of weeks and like it. The only app I can't find that works is a basic mp3 splitter .... does anyone know one that works and is preferably free :D
Software and Apps
Don't see the optical drive unless you start it up?
Does anybody else find it a bit disconcerting you don't see the optical drive unless you start it up?
Drivers & Hardware
