"VIA HD AUDIO DRIVER" Installation Error !!
JOYGR11
Kolkata, India
can't install VIA HIGH DEFINITION(HD) AUDIO DRIVER in Windows 8 Dev. Preview x64.tried 4 to 5 different versions.but none of them would install.i can't get FRONT PANEL HEADPHONE output with default Windows audio.speakers works fine.
error :
    WINDOWS 8 Consumer Preview x64
    Assembled
    INTEL CORE I5 2400
    Gigabyte GA-H61M-S2P-B3 (rev. 1.0)
    Corsair XMS3 (2x4GB) 8GB DDR3 1333 MHZ
    PALIT (NVIDIA) GTS 250 1GB
    Inbuilt (VIA VT1708S)
    Samsung Syncmaster 2033SW
    1600 x 900
    Western Digital (WD) Caviar Green 1 TB
    Western Digital (WD) Caviar Green 500 GB
    CoolerMaster Extreme Power Plus 600W
    Generic Mid-Tower ATX (Frontech)
    x2 CoolerMaster LED 12CM Chassis Fan
    Logitech Multimedia Keyboard
    Logitech PS/2 Mouse
    512 kbps Broadband
Welcome to Eight Forums Joygr11. Is this a laptop, what graphics card, motherboard make model?
You could try installing in compatibility mode for Windows 7 SP1.
    Win 7 Ult X64 SP1
    H.A.L. 2000
    i5-2550K @ 4.4GHz, today
    ASUS P8Z68-V PRO/GEN3
    16GB GSkill Sniper 2133 MHz
    ASUS GeForce 650Ti Boost
    Realtech onboard
    Samsung P2570HD
    Samsung 840 PRO OS, Seagate Constellation 500GB, Users
    Corsair HX650W
    Inwin Dragon Rider
    120mm X4 case fans 3 intake, 1 exhaust , 120mm X2 CPU cooler fan
    some old Dell I found
    steelseries Sensei
    50Mbs/11Mbs
    IE11, Pale Moon, Opera
    NIS 2013
    LG BluRay BD/RE, DVD/RW, front panel w/USB, eSATA, Audio, multi-card reader, Mr Fusion generator
via hd audio 100% working
i can confirm it works in compatibility mode for Windows 7 SP1 , but after instalation you must set compatibility mode to hd vdeck software stored in "C:\Program Files (x86)\VIA\VIAudioi\VDeck\VDeck.exe" its working 100%
    7 x64
following the message via HD driver to be updated
I changed via hd audio to win7 compatibility and yes it does work and opens in control panel.
However a nasty side effect is the windows sidebar and all gadgets failed to work
I had a volume control gadget in there but it knocked out all gadgets ie no sidebar capability
Uninstalling via hd software all gadgets were restored.
    xp , 7Pro, 8RP, Android phone, Tablet
    Custom
    q6600@3Ghz, amd 965 etc etc
    gigabyte
    8gb per
    gts450 ,560gt etc
    3xsamsung 24in
    3, 1920x1200
    To many! spread across 4 desktops,3 laptops 1 netbook
    ssd, sata 3's ide etc
    Hyper Modular 600W
    lian li
    artic
    60Mb
    Basically the house has 4 desktops 3 in the study + the wifes,
    3 laptops 1 netbook 2 android tablets 2 android smart phones
    and ipad and iphone
error :
My friend i dont know english so much but i can help you with this trouble!! the tips .... right click on SETUP.EXE driver, propieties---> compatibility---> clic on box OS (windows 7) and run as admin!! ___> apply---> accept.
start the setup.exe again and install like any program. when the driver is installed, the OS will open a message: the vdeck is not compatible with this OS. later you try to open the vdeck app and the OS show you a option ( run this app with the compatibility mode/the application run correctly) you select the firt option (compatibility mode) and BUALA!!!! your vdeck is running perfectly.
I was searching a solution in this forum but NOTHING. later id try and GOD help me!!!!
    win 8
