Front Mic Not Being Picked Up
    Alright, so I've had this problem ever since I upgraded to Windows 8.
    I was initially a Windows Vista user, and this headset worked perfectly fine on the Vista Home Premium OS. However, ever since my upgrade to Windows 8 Pro the microphone refuses to pick up sound.
    I have done everything from uninstalling and reinstalling the drivers, Realtek specifically to plugging it in through the back of my tower. I can say without a shadow of a doubt that it is not a hardware problem, as I use this same headset with my Xbox 360.
    I've gone in and changed the settings via the sound menu, I have done literally everything I can find thus far. The microphone is detected, however there is constantly one bar of sound pick up from the microphone. My voice isn't even picked up from the Microphone set up menu. I've unmuted the front mic through the sound menu as well, but I still get nothing. I've reset everything to default countless times, and I still get no results.
    The headset I am using specifically is the Red Samurai Xbox 360 Stereo Headset. I just can't figure out what is wrong.
    Any help will be greatly appreciated.
    Click image for larger versionClick image for larger versionClick image for larger version
    First thing, are you using the Dell supplied sound driver? If not, that is the first thing - install the Dell sound driver. I did support on the Dell forums for many years and we found in most cases non-Dell sound drivers either do not work or do not work correctly.
    Here is the Dell driver for Vista, which will work on Win 8, as Dell does not officially support drivers above Vista on this model. Driver Details | Dell US
    You should also set the Stereo Mix as the default recording device, then any mic or line in or streaming audio will be recorded. This won't fix the low mic level but is the "normal" recording device setting.
W8.1 No sound coming from the front.
Hi. I have so many problems with windows 8.1 i have seriously no idea where to begin. First one i would like to have fixed is this damn sound, happened to me first time i installed windows 8.1 aswell, and i have no idea how i fixed it. The speakers are set to Quadraphonic, i have tried all...
USB 3.0 Pendrive not working in front usb 2.0 port
Hey guys i bought hpx705w usb 3.0 drive.Its not working in front usb ports of my desktop but works fine when plugged in back usb ports.And also works fine on my laptop usb ports. What should i do ? Running windows 8
Drivers & Hardware
No sound from front panel
Yeah so my front panel is connected to my board but im still not getting any sound Usually in the good'ol versions i would disable front panel detection from the realtek driver utility but i dont have that on this computer
go to desktop from front screen loops every 5 sec
start up laptop - select to go to desktop (apologies if wrong term) dropping back to windows 7 looking desktop - after a bout 5 secs, refreshes itself so you can never select anything or breakout.. No idea what to do!
Audio Front Panel not working
Front panel no left sound
Hello, I've got an Z77 Pro3 mobo (Asrock) and a Bitfenix Shinobi case. I've installed the HD-audio plug from the case to the motherboards hd-audio place correctly. My problem is that the case's front panel gives sounds only to my headsets right side but not to the left side. The microphone...
More news on the microsoft front.
Read ALL about it here. Can Office 365 convince you that renting software is a good deal? | ZDNet :mad:
