I'm currently having some issues with my Steelseries 5Hv2, my system will not pick up the headset. I've tried this through both the jack on my logitech g110 and the jack on the mother board and no luck. The headset will play sounds when connected to my TV and other PC's, so I would assume the problem is with my PC. Other headsets are currently working fine (tried using my old one). So I'm not sure what the issue could be.
Anyone else had this problem, or does anyone have any ideas what could be causing this?
