Disable Microphone monitoring
    Windows 8.1 Pro X64
    How can I disable the microphone monitoring?
    Now, when I speak, I can hear my voice in the headset with a small delay.
    When I go to the Sound -> Microphone Properties, the "Listen to this device" checkbox is already un-checked in the "listen" tab.
    Any suggestions?
    In almost all cases (all that I've seen), you can't disable it. That is the reason many use a headset/mic combination to minimize feedback problems.
    Did you install proper audio drivers for that MB or you are using default win drivers? Manufacturers drivers usualy have more options for it. In my case Realtek drivers have an option for microphone monitoring and it works well from it's own control panel.
Performance Monitoring
Hey, I was a huge fan of Core Temp and it's Win7 gadget widget and I looked nice on my second monitor, since Win8 no longer supports gadgets (to my knowledge) I am looking for a nice core monitor that does what CoreTemp does, Fan speed, core temps, RAM and even ethernet speed. I would like it...
Software and Apps
Monitoring core performance
Windows 7 had a really nice desktop gadget for monitoring the core distribution on my dual-core machine. I just tried to find something similar for Windows 8 but I couldn't find any desktop gadgets at all.... :cry: Have they gone forever or can I re-instate them somehow?
Performance & Maintenance
PC Monitoring Software
Are there any good apps that does this? Also any that can report directly to my LCD display on my keyboard. I have an old version of Aida64 but don't wish to upgrade that as it costs too much.
Can't disable Sensor Monitoring Service
Hey guys, so like many others I am having problems with Windows 8's adaptive brightness feature. It's really starting to bug me, so I've tried to disable it. I don't have the Disable Adaptive Brightness menu as described in this fix, so I followed these instructions. After disabling and turning...
Drivers & Hardware
A little help about uploading and its monitoring on win 8.
Hi to everyone. I m uploading something on facebook via firefox. when I see uploading monitor in task manager, in process tab, FF show that it uploads data in 0.1 mbps where performance tab shows data sent with 1mbps speed. I don't upload something else from my computer. so why the uploading...
Network & Sharing
download and cpu monitoring
In vista i had 2 gadgets that ran, one was for monitoring cpu usage and the other was for download speed.. the cpu one was called all cpu meter, not that the name is important. my question is this, does anything like this exist in windows 8? can i use that same gadget in windows 8? if so how do i...
Software and Apps
SIW system sensor monitoring
I tried to download and install SIW, but it's not compatible with this OS. Has anybody found a work around or a nice substitute? I grabbed the trial version of AIDA64 and it works well with 8, but it's just a 30 day trial version.
Software and Apps
