AMD HDMI Output [Not Plugged In]
    Windows 8 x64
    Okay so, my computer recently crashed and had to reformat it.. lost everything
    Everything was working just fine, until I had to reformat.
    Now, I have no sound at all coming from my headphones and it says that the AMD HDMI Output is not plugged in.
    I don't really know how to fix this..
    Before reformatting, I was using these 2:
    But then switched to this:
    I don't know if this can affect anything..
    Here's what I have
    Headphones: Astro A50
    Monitor: Asus VE278Q
    Graphics Card: AMD Redeon HD 7570
    CPU: Intel Core i7-3770
AMD HDMI Output 'not plugged in', no sound
Hi all. I sucessfully got bootcamp to work on my iMac, and the only issue that I have run across is that I do not have any sound whatsoever coming out of my speakers. The sound icon just remains at the speaker with a red cross, and no matter what I do, I just can't get it to work. In...
FIX - AMD HDMI no sound output to monitor speakers
Problem: AMD HDMI output would not play sound via HDMI cable to monitor speakers. Testing the AMD HDMI sound output gave the following error message: Device in use by another application… This FIX worked for this hardware configuration. · MSI motherboard · Realtek Audio...
Audio Over HDMI Cable Not Working - HDMI Cable Not Plugged
Basic Specs Brand New Toshiba Satellite C855 Win 8 64-bit 6 GB RAM Display Adapter: Intel(R) HD Graphics (2000) Driver: Intel Playback Devices
No audio output through HDMI port to TV
broke or damage my HDMI output
HI, I'm new here. I run the sfc /scannow like 5 times because when I did it, it broke or damage my HDMI output. The only problem my sfcdetails.txt file shows is that it cannot repair Amd64\CNBJ2530.DPB of the prncacla.inf file due to a hash mismatch. But you already wrote that it doesn't had to...
HDMI output not working
Hey guys, I have an ASUS s550C running windows 8 and my HDMI to my 32" RCA flatscreen doesn't work anymore. The cable works fine with the xbox, correct tv modes, but now as soon as I plug in the HDMI to the Ultrabook the Ultrabooks screen goes black and the tv screen says unsupported. What gives?...
Graphic Cards
HDMI Sound output issues
Hi there, new to this forum but i've been searching around today trying to find an answer to this problem i'm having. I've bought an HDMI cable to connect my laptop to TV, i've gone into the control panel and checked that "show disabled devices" and "show disconnected devices" are both...
