CONCLUSION
_________________________________________________________________________________________________________
Your system seems to have difficulty handling real-time audio and other tasks. You may experience drop outs, clicks or pops due to buffer underruns. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:02:50 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: SWEDINATOR
OS version: Windows 8 , 6.2, build: 9200 (x64)
Hardware: ASUSTeK COMPUTER INC., P8Z77-M
CPU: GenuineIntel Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
Logical processors: 4
Processor groups: 1
RAM: 3781 MB total
CPU SPEED
Reported CPU speed: 3410.0 MHz
Measured CPU speed: 2153.0 MHz (approx.)
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 1007.479371
Average measured interrupt to process latency (µs): 6.240863
Highest measured interrupt to DPC latency (µs): 956.429745
Average measured interrupt to DPC latency (µs): 1.063419
MEASURED SMI, IPI AND CPU STALLS
The SMI, IPI and CPU stalls value represents the highest measured interval that a CPU did not respond while having its maskable interrupts disabled.
Highest measured SMI or CPU stall (µs) 20.419850
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 278.628739
Driver with highest ISR routine execution time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Highest reported total ISR routine time (%): 0.009463
Driver with highest ISR total time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Total time spent in ISRs (%) 0.022007
ISR count (execution time <250 µs): 29158
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 1
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 515.675073
Driver with highest DPC routine execution time: ndis.sys - NDIS 6.30 driver, Microsoft Corporation
Highest reported total DPC routine time (%): 0.067873
Driver with highest DPC total execution time: rspLLL64.sys - Resplendence Latency Monitoring and Auxiliary Kernel Library, Resplendence Software Projects Sp.
Total time spent in DPCs (%) 0.295217
DPC count (execution time <250 µs): 661502
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 35
DPC count (execution time 1000-1999 µs): 0
DPC count (execution time 2000-3999 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
Process with highest pagefault count: iexplore.exe
Total number of hard pagefaults 371
Hard pagefault count of hardest hit process: 222
Highest hard pagefault resolution time (µs): 779.338710
Total time spent in hard pagefaults (%): 0.008227
Number of processes hit: 12
PER CPU DATA
CPU 0 Interrupt cycle time (s): 5.152257
CPU 0 ISR highest execution time (µs): 83.571261
CPU 0 ISR total execution time (s): 0.088733
CPU 0 ISR count: 17515
CPU 0 DPC highest execution time (µs): 515.675073
CPU 0 DPC total execution time (s): 1.262402
CPU 0 DPC count: 560744
CPU 1 Interrupt cycle time (s): 2.121042
CPU 1 ISR highest execution time (µs): 92.472727
CPU 1 ISR total execution time (s): 0.029702
CPU 1 ISR count: 5746
CPU 1 DPC highest execution time (µs): 396.962463
CPU 1 DPC total execution time (s): 0.300197
CPU 1 DPC count: 39743
CPU 2 Interrupt cycle time (s): 1.945427
CPU 2 ISR highest execution time (µs): 278.628739
CPU 2 ISR total execution time (s): 0.019235
CPU 2 ISR count: 3651
CPU 2 DPC highest execution time (µs): 304.817302
CPU 2 DPC total execution time (s): 0.255234
CPU 2 DPC count: 34355
CPU 3 Interrupt cycle time (s): 1.907956
CPU 3 ISR highest execution time (µs): 99.733138
CPU 3 ISR total execution time (s): 0.012074
CPU 3 ISR count: 2247
CPU 3 DPC highest execution time (µs): 382.992082
CPU 3 DPC total execution time (s): 0.190931
CPU 3 DPC count: 26695
