Headphones not working on Acer Aspire 5820T-6825
checoimg
I upgraded to Windows 8 and now I noticed that the headphones won't work. First I followed some troubleshooting that concluded on uninstalling the audio drivers including some Intel version of the driver and then when I rebooted then the sound worked.
Now it happened again and I really don't want to be uninstalling the driver every time I want to use the headphones.
I downloaded the latest driver on Intel site and updated but no results.
I checked on sound settings and there are no headphones detected. Maybe there is some way of forcing the detection.
Name of the Intel to driver: AUD_Win8_Win7_6.0.1.6914_PV.exe
Thank you for your attention.
    Windows 8 64 bit
    Acer
    i5
    Intel
    FF
    Avast/ClamWin
I just uninstalled the driver and rebooted to make it work and I don't see the headphones in the mixer or sound card settings ( playback tab ).
    Windows 8 64 bit
    Acer
    i5
    Intel
    FF
    Avast/ClamWin
Ok I restarted without the headphones plugged and sound works now.
The steps where :
1) Install latest sound Realtek driver from Intel. That takes two reboots, one to uninstall the current driver and one to install the new driver which auto starts on the next session.
2) Open Device Manager and uninstall High Definition Audio Device ( not the Realtek ).
3) Reboot and there you go.
Hope this helps.
    Windows 8 64 bit
    Acer
    i5
    Intel
    FF
    Avast/ClamWin
Bad news it happened again! I needed to unsintall the driver and reboot again. Before it lasted more than two boots so that's why I thought it was fixed.
    Windows 8 64 bit
    Acer
    i5
    Intel
    FF
    Avast/ClamWin
Forgot to mention that maybe is a two drivers conflict. Is there something like a System Summary in Windows 8 ?
    Windows 8 64 bit
    Acer
    i5
    Intel
    FF
    Avast/ClamWin
Found System Summary
Right now there's no problem with audio. I'll do another System Summary when it fails.
  • drivers.txt
    Windows 8 64 bit
    Acer
    i5
    Intel
    FF
    Avast/ClamWin
Well the same problem again after reinstalling windows.
There's the system summary I dunno what else to provide.
  • sound_driver.txt
    Windows 8 64 bit
    Acer
    i5
    Intel
    FF
    Avast/ClamWin
Updated to latest realtek driver.
Here is the system summary with the latest driver.
  • sound_realtek.txt
    Windows 8 64 bit
    Acer
    i5
    Intel
    FF
    Avast/ClamWin
Are the headphones USB or jack type ?
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
Try going to Action Center & clicking on the Troubleshooting link.
In the window that appears audio options are available.
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
I tried troubleshooting sound playback and nothing.
    Windows 8 64 bit
    Acer
    i5
    Intel
    FF
    Avast/ClamWin
Do you have regular speakers ? & if so, do they work ?
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
I have a set of jack type headphones.
I just plugged them in & have no sound in them.
I'll try to get them to work & post back with results.
My usb headphones work ok.
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
Yes my speakers work fine. I'll wait for you then.
    Windows 8 64 bit
    Acer
    i5
    Intel
    FF
    Avast/ClamWin
I went to sound in control panel & tried Stereo & no sound.
I switched to quadrophonic & I got sound !
I tried stereo again & got sound !
Try it & post back please.
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
I set the Logitech usb phones as default communications device since they have a microphone too.
I set the jack phones as default sound device.
I have to switch back & forth between them in mixer though, depending on which ones I want to use. :)
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
Still no sound yet.
I don't have that many options to switch on.
Only stereo which doesn't work with headphones on.
Maybe the only thing working is the switch that turns off the speakers still I don't see headphones identified by the computer and the signal still goes to the speakers.
The is a digital output from realtek but I think it's bogus since is saying it has an optical jack and I don't see anything there.
Where the headphones go outside says SPDIF I think. It's very small.
    Windows 8 64 bit
    Acer
    i5
    Intel
    FF
    Avast/ClamWin
They are the same output
The Headphones and Speakers are joined in one device. When I enter in the speaker configuration I can see the 3.5mm jack and that's why the signal in the mixer is the same but still no sound.
    Windows 8 64 bit
    Acer
    i5
    Intel
    FF
    Avast/ClamWin
