Undo "don't use this device"??
    I'm using Windows 8. I disabled my surround sound headphones (with mic on headset) by going into properties and selecting "Don't use this device (Disable)", in an effort to fix the background static noise I was getting because every time I took them out and plugged them back in, I got a different result.
    I need to re enable the device now to use the headphones but I don't know what to do anymore. I tried taking the headphones out and plugging them back in to see if it would recognize them again, but it's as if they don't exist. I also went to the control panel, device manager and tried to add new device--- it did not detect any headphones. I'm going out of my mind, can someone point me in the right direction? My headphones are quite expensive, don't want to have to buy new ones!
    Thanx in advance.
    Windows 8 Pro Windows 8.1 Preview
    Type "sound" into the search box. look at the search results and click "change sound card settings." Hopefully, you'll be able to enable your headphones in that view. Good luck.
"Loading files ..." -> "Windows Boot Manager" -> "OneKey"
HDMI Audio Device "Not Plugged In" post Windows 8 upgrade.
Asus Laptop/RealTek "No Audio Output Device is Installed"
Device manager shows "Unknown Device" on reinstallation of driver
Hi, On a fresh clean Windows 8 image, my software driver (signed) installs fine and shows up properly in the Device Manager. However once i uninstall it , subsequent reinstalls show up as 'Unknown Device' in the Device Manager. From the device details, I find that it refers to /looks for the...
Drivers & Hardware
How To Undo "Open With..."'s been a problem with all versions of Windows since the old days... How do I undo an "Open With..." assignment? I want to go back to the default state Thanks for reading
Software and Apps
Booting from DVD issue, "Reboot and select proper boot device".
Hi! I just burned a copy of the Windows 8 Developer Preview onto a DVD. I have created a partition for the new OS (because I don't want to install over Windows 7). When Windows 7 is running and I pop in the DVD, the computer directly recognizes it as a runnable program. I'm also able to install...
Installation & Setup
