VIA HD Vdeck "We Can't Find HD Audio Device" Error
broro07
    Windows 8.1 Pro Previer
    Custom Build
    AMD Phenom(tm) II X4 820 2.8 GHz
    Biostar N68S3B
    X2 4GB DDR3
    NVIDIA GeForce GT 520
Check to see if you have installed the chipset driver or if there is an updated chipset driver for your mobo.
    Custom build
    AMD Phenom II X 4 965 BE
    Gigabyte GA-MA790X-DS4
    G-Skill 8 GB PC 8500
    AMD XFX HD Radeon 6790D
    Realtek HD onboard
    2l Samsung SyncMaster S20B300
    1600 X 900
    Seagate Barracuda 320 GB w/OS
    Cooler Master Hyper212 120mm
    Logitech G510
    Razor DeathAdder 3.5
After checking your mobo's page you linked to...seems like that mobo doesn't support windows 8. I only see 2 drivers for windows 8 and those are the LAN/Audio drivers. The drivers that are there don't say what brand/manufacturer they are, very hard to decipher. I'm not a big fan of BioStar anyway.
    Custom build
    Realtek HD onboard
    1600 X 900
    Logitech G510
Everything else works, and it says the drivers will work on Windows 8.
    Custom Build
    Biostar N68S3B
    X2 4GB DDR3
Go here and see if you have an option for surround sound. I do not have that option because I only have two speakers connected:
Note: click configure to bring up the view on the right:
    Windows 8 Pro Windows 8.1 Preview
Nope, Nothing. I had my sub plugged into the mic jack on my mobo cause vdeck let me use it as an output. If you know of another software that does this PLEASE TELL ME!!!!
    Custom Build
    Biostar N68S3B
    X2 4GB DDR3
