Sound Card Recommendations
    I am looking for a decent quality sound card for the rig that is detailed in my profile. I have a budget of around 60 I was wondering if anyone on here can recommend a good sound card or if anyone has any experiences with any?
    Thanks for your help.
    I have a recording studio with high end audio gear and speakers. But, for PC audio, I find the in built RealTek on my Gigabyte motherboard is more than adequate.
    HT Omega 7.1 used in my desktop for years now had a Bluegear's model before and lasted 1 year.
    I used an HT Omega Striker 7.1 on an old PC. But, its PCI, not PCIe like most new motherboards have.
Best Sound Card for Beats Studio
Hi, I am considering to make a Editing PC to make Dub step on, I am definitely getting a pair of Beats Studio Headphones, I wondered what will be the best sound card(I am only using 1 pair of headphones)
Sound Card not working
Irql_Driver_No_Less_Or_Equal (cmudaxp.sys) -- Sound Card?
EDIT: I fixed it by uninstalling the xonar dg drivers, shutting down, then removing the sound card. Why did I buy this thing anyways.. the onboard sound sounds just as good. -All Windows 8 updates installed -All drivers I could possibly think of to install, installed This all started when I...
BSOD Crashes and Debugging
Sound Card Issues
Every 5 days or so, my sound card will have a bad day, and all noise coming through my headset will be distorted and static-like. Usually restarting my computer will fix it, but today it stopped working altogether. I check the computer, and it says that no headphones or audio are plugged in. I...
Sabrent SBT-SP6C sound card
By any chance anybody has this card and figured out how to get this card to work under Windows 8? There's no W8 driver and W7 driver doesn't work.
Drivers & Hardware
Virtual Sound Card?
I just bought new speakers and want more boom out of the sub so installed SRS audio sandbox. it tells me on startup however that there is no compatible sound card to use. I am running windows 8 on a laptop so I cannot install a sound card. is there any way I can emulate a sound card so I can use...
