HDMI Audio issues. Full screen video mutes (and more).
    Windows 8 Pro MCE
    I just installed Windows 8 Pro on a new machine.
    I carried over my HD7970 from my old Windows 7 machine. I had absolutely no issues with audio in Windows 7, but Windows 8 has been a huge pain in the ass.
    I have two displays, an HDTV connected through HDMI and an older LCD connected via DVI.
    All my audio comes through the TV. In fact, I've disabled the onboard audio device on the motherboard. So I am strictly using the Radeon card for audio.
    One thing I noticed is that the Audio tab in the Catalyst Control Center says "Your displays do not support audio...", but it shows my Panasonic TV in the Playback devices. The playback does work, but I get weird mutes.
    If I go full screen in Youtube or Netflix the sound mutes for like 30 seconds. When I do ANYTHING (change tabs in Chrome, click a link, move windows around in a VM) on the other display, the sound mutes for 30 seconds. I basically am unable to do anything on my other display while something is streaming. It's irritating beyond belief.
    Does anyone have a solution for me?
    Windows 8 Pro MCE
    Well, for a while my problem was solved. I uninstalled the Realtek drivers (since I wasn't using the device) and reinstalled the AMD drivers and all seemed fine for a while. But I just started my computer up after I had put it to sleep and it's doing the same thing again, even after a restart.
    Going to reinstall the AMD drivers again.
    Windows 8 Pro MCE
    I thought I'd let you know that when I have the issue with Youtube videos, I am also unable to here sound in games.
    Right now I've only installed Rift.
    Hafnarfjörður IS
    Hi there
    I'm not sure with DVI but I think you need to disconnect the DVI to get HDMI audio into your monitor -- I think you can only on standard audio only have ONE digital output working at once.
    You can connect both RGB and HDMI concurrently - when you switch the monitor to RGB the audio will switch to analog and you'll need a standard audio cable to use the audio.
    I don't think (although could be wrong of course) that it's a matter with the drivers but a configuration issue on both the PC and the monitor.
Black screen while video playback (Audio only)
Hey guys. I discovered that besides VLC player on my laptop all the other video player are not able to work properly (meaning,, Windows Media Player 12, Cyberlink PowerDVD12 and WMPC are able to play only the audio, but not the video, it's just black screen),, BUT with VLC is no problem playing...
Graphic Cards
Having a lot of issues with windows 8. (audio/video/more)
Okay, let me flat out start with, I can NOT stand to use windows 8.1. I am very familiar with W7 and XP but windows 8 just looks, and feels like it was made for a 9 year old who out grew his tablet. I have had this machine for about 3 months now.... I honestly do not enjoy using it...
Full screen flash video very poor quality
Whenever I go full screen on youtube it looks terrible. I have searched and searched and have no idea how to fix this. Can't even find someone with a similar problem. Blurry and 256 colours. Something similar happens to the desktop when I leave fullscreen from VLC or VirtualBox. That makes sense...
on closing laptop i lose full screen on tv hdmi
hi sorry if this post is in the wrong place, i'm new. i finally worked out how to get full screen on my tv when connected via hdmi from laptop, which is great. only now found that when i shut the laptop screen i lose the full screen on the tele and it sizes down to about 50% with the black...
Graphic Cards
Full-screen games having issues when windows pop up
Okay, I'm sorry if that title is a little vague but this is a really bizarre problem I've been having since I changed to Win8 and I can't really find anything on it. So here's the deal, I use tweetdeck a lot, a twitter client for the desktop that notifies you of new tweets and such with a little...
video opens in full screen
Win8, running on desktop, no touchscreen. In Win8, I opened for the first time a video, with the video app. It opens in full, maximized screen. In Win7, for example, when opening a video (with WMV) the usual minimize, maximize/adjust size buttons appear in the upper right corner of the...
Help! Taskbar overlaps full screen video can't get to the bottom menus
Here is my problem. When watching videos on utube or any other streaming channel on full screen the controls are on the bottom behind the taskbar. How do I get the controls for the video player on top of the taskbar??? I have to autohide the task bar in order to get to the video player controls....
