I need to sleep to enable sound
    Windows 8 64 bit
    I need to sleep to enable sound in external speakers
    My problem is that I have to use 'sleep' option to enable sound in external speakers (the builtin Asus laptop's speakers work). I have to do it always after starting Windows 8. It's a dualboot system with Linux, so I had to disable faststartup and hibernate options the below way: Fast Startup - Turn On or Off in Windows 8
    I'm not sure if this is the reason, bacause I rarely use Windows. It's Windows 64b. I use Realtek drivers provided by Asus and also tried to remove them (so the ones that come with Windows work I guess) but it doesn't work too.
    I'd appreciate any suggestions...
    First, the ASUS supplied drivers should be used. The Windows installed sound drivers are only basic function drivers.
    Check what is shown installed in the Device Manager for the Sound. You should only have the RealTek and possibly HDMI (If you have HDMI capability). If there is anything else installed there, such as the Windows HD Audio Codec, uninstall that (and then restart the PC after you uninstall).
    The external speakers, I assume, are being plugged into the headphone jack.
    It sounds like some other program has the sound "captured" and restarting (or sleep/restart) is freeing it up. If you have any other program running such as Skype, temporarily disable that and see if you still have the problem.
    Windows 8 64 bit
    Device Manager shows Realtek and HDAD in 'Sound, video and game controllers'.
    Yes, it's heaphone's lineout jack.
    I don't use Skype or anything like this, there's not many things installed as it is quite fresh installation.
    And, btw, restarting computer doesn't help - it's actually the source of the problem, because sound is working without problems but it's broken when I restart. The only thing that helps is to go 'Sleep' option and back. It's not very problematic but I have to do it every time I start system...
    Uninstall the HDAD in the sound. It shouldn't be there and can cause conflicts.
    However, you should have an HDMI audio entry for the NVIDIA video (assuming you have what is shown on the web site for this model).
    There should be two entries, one for the HDMI audio and one for the PC audio (RealTek).
    Windows 8 64 bit
    I wonder what model do you check, I didn't post the information... It's HD4000+Geforce model - maybe that's the reason it's not on the list?
    Will remove it and post what's the result. I thought the HDAD is the HDMI driver that you mentioned.
    It didn't help. Still no sound in external speakers after restart. Also, HDAD was automatically reinstalled after restart.
    HD4000 would be the Intel graphics (graphics built into the Intel CPU). GeForce Is NVIDA graphics.
    Right click your sound icon, select playback devices and tell us what is your default playback device. It should be your realtek speaker...if anything else is checked, then there's your problem.
    Windows 8 64 bit
    Realtek is default.
    With the dual boot setup you have, what is the primary OS? Does it use windows to give the the choice of boot options or is it your linux version. I mean when you first turn on your PC is it the linux boot mgr that you see or windows boot mgr?
    You could try running "sfc /scannow" with out the quotes in a cmd prompt for corrupt or missing system files.
    Windows 8 64 bit
    I use Linux Grub2 bootloader as deafault, but I don't start Windows 8 using it. When I need to run Windows 8 I just press ESC (or go to BIOS) and choose Windows.
    "sfc /scannow" result:
    C:\Windows\system32>sfc.exe /scannow
    Beginning system scan.  This process will take some time.
    Beginning verification phase of system scan.
    Verification 100% complete.
    Windows Resource Protection found corrupt files but was unable to fix some
    of them. Details are included in the CBS.Log windir\Logs\CBS\CBS.log. For
    example C:\Windows\Logs\CBS\CBS.log. Note that logging is currently not
    supported in offline servicing scenarios.
    The system file repair changes will take effect after the next reboot.
mobo sound and HDMI sound not synced in Windows 8.1
No sound on start-up, Win8 needs time to output sound
Samsung np-355vc uk sound drivers installed, but no sound?
What does sleep mode sound like?
Might sound like a daft topic title but bear with me. After my upgrade to 8.1 Pro my computer lost the ability to sleep/hibernate. After following many tips on here (thanks guys), I managed to get sleep & hibernation onto the shutdown menu so manual operatin works okay. The automatic mode is...
Windows 8 not seeing USB sound card after wake from sleep
Hi. I have a home built HTPC running Windows 8 with Windows Media Center. My sound card is a Silverstone EB01 USB DAC (i.e., it's an external USB device). When the computer wakes from sleep, there is no sound. I can fix this by either (a) unplugging and reconnecting the USB connector or (b)...
No sound after waking from sleep mode in Windows 8
I'm getting no sound after resuming from S1 sleep mode in Windows 8 and the only way to fix this is to either physically unplug the audio cable and plug it back in or restart the computer. I tried the audio troubleshooter and it could not find any problems and there is nothing to fix. I need to...
"Windows To Go" Sleep - Enable or Disable in Windows 8
How to Enable or Disable Sleep in "Windows To Go" Workspace This tutorial will show you how to enable or disable standby sleep states (S1-S3) on the Windows 8 Enterprise "Windows To Go" workspace USB flash drive. You must be signed in as an administrator to be able to do the steps in this...
