Game Audio Not Playing through Headphones
    When my Turtlebeach x12 is plugged into my computer (runs Windows 8) and I try to launch some steam games the audio plays through the built-in speakers rather than my headset. I've played around with default devices and disabling/enabling different devices, but nothing has worked. In some games like Planetside 2, the in-game option to set the output device to the headphones works perfectly, but in most other games (e.g. Left for Dead), audio still plays out of my speakers. When I disable the speakers there is no game sound at all. This also wasn't an issue on my old laptop that runs Windows 7. Is there any way to here the game audio from my headset? Any help would be much appreciated
    Maryland USA
    Do you plug in the headset after you start the game?
    Try plugging in the headset before you start the game and see if that helps..
    In your sounds setting do you have an option for "speaker and dual headphones"?
    Heres a link with that issue and how it was resolved.
    Sound won't play through headphones - Forums - StarCraft II
Split Audio, one app to HDMI/TV, another app to headphones
Sound playing through both laptop speakers and headphones
I bought the plantronics .Audio 335 studio headphones, but when I plugged them in, it screwed up my sound. My compute'rs sound is now playing through both the headphones AND the laptop speakers. After unplugging it and trying again a couple times, I gave up and decided to just use my old...
BSOD when playing any game
Hi, first time using the forum. I recently purchased a 2nd hand PC back in June and unfortunately have experienced about a dozen BSODs when playing games. They seem to occur randomly. There has been times where I have been able to play games for hours without BSOD at all. I thought it was an...
BSOD Crashes and Debugging
BSOD while playing a game
I hope someone can help my computer crashes every time I play any game I have. So I hope someone can see what the problem is from the crash report I have or do I have to do a total reinstall of everything? Thanks for any help you can give.
BSOD after playing a game for a while
So ive been experiencing a BSOD after i downloaded a new driver for nvidia 320.49 then in kept crashing when i was playing a game with the error VIDEO_TDR_FAILURE (nvlddmkm.sys) and a while later it crashed that when i start my pc it enters sign in screen and when i sign in a black screen shows up...
Audio only playing through headphones
Hi, I have an HP Pavillion DV6 3216 US entertainment notebook which does not currently have functioning audio. I have no audio coming through the built in speakers (I've tried fiddling with the playback device options/properties/testing the device to no avail) but do have audio when I plug a pair...
Audio coming from both Headphones and Speakers from my dell 15R.
