No Sound from X-FI Xtreme Gamer
    Windows 8 Dev Preview
    Im afraid that I have my soundblaster X-FI Extremegamer running fine. Or as fine as it can be running given that Windows 8 is still buggy as hell.
    Quote Originally Posted by deathjesteruk View Post
    Scratch that, I installed the driver for my extreme gamer and was continually crashing. Infact, even after a total reinstall without installing the drivers, it was crashing. I have now removed the soundcard entirely and am using my onboard sound. So far so good, I will let you know how it goes.
    Windows 7 x64
    This is a widespread issue currently for various X-fi cards. People can be a little confused at first because the issue isn't apparent right away after installing the drivers and apps - most people (including me) report that the problems happen after restarting the system and finding that settings have reverted to default (in the Console Launcher) and that there's no sound. If you click on "default", the sound should come back - but this is not a fix, as it's not an option to do this upon every boot/reboot. Your problem might not manifest itself as mine does, but all in all, X-fi and Windows 8 do not work well together at this point.
    Windows 8 Pro x64 Retail No Sound after Restart Creative X-Fi Titanium HD Driver
    USA/Tenn/Oak Ridge
    Win 8.1 Pro 64 Bit
    Yea.. I have the same issue. And the same issue was occurring with Vista, it seems to me at least that Creative has issues with their drivers.
    USA/Tenn/Oak Ridge
    Win 8.1 Pro 64 Bit
    I found one way around this issue. I re-installed the Win 7 drivers for the sound card. Then I restated the PC. When it was up and going I went into the Creative control panel and selected the Entertainment mode.. the sound was back. I have not tried this with the beta drivers.. but it might work. HTH
    My X-FI card stopped working yesterday after installing a driver update through Win8 Update. I rolled back the driver and the card works fine now. How can I see the updates that Windows Updates is applying? Thnaks!
    USA/Tenn/Oak Ridge
    Win 8.1 Pro 64 Bit
    I wish I could help you on that. I hope someone else can answer,.
    Windows 8 Pro
    Quote Originally Posted by omnimodis78 View Post
    works for me I had same prob try adding this to the reg ...
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
    "CtxfiReg"="CTXFIREG.EXE /FORCE"
    USA/Tenn/Oak Ridge
    Win 8.1 Pro 64 Bit
    I just tried the Beta driver from Creative and so far so good.
Page 1 of 2 12 LastLast
The Creative Sound Blaster X-fi Xtreme Audio card works fine in Windows 8. The drivers for Windows 7 work without any problem and the Creative updater and control panel also work as they should in Windows 8. The drivers can be downloaded here for the X-Fi Xtreme Audio card - Creative Worldwide...
PC infected with XTreme Rat
Hi, I recently installed AVG on the family computer and ran a virus scan, which came up with a few problems. The biggest one was that the computer was infected with the XTreme RAT trojan. This has been removed, but looking at the capabilities a RAT gives I would like to see what damage has...
System Security
Anybody still using x-fi xtreme gamer on windows 8.1 ????
Hi, i'm curious if anybody is still using their x-fi xtremegamer soundcard on windows 8.1 OS. I really wanted to dump it and use my onboard realtek ALC892. But, the audio to my surprise was inferior. Odd that a card I acquired in 2008 still beats out a modern onboard sound solution even...
Drivers & Hardware
Xbox live gamer tag
My gamer tag is not associated with my main Microsoft account that I use. It seems like a big pain to have to create a whole new user and switch to it in order to use the xbox live app. Does anyone know if there is anyway to log into a different Xbox live gamer tag than the user account you are...
Gaming
Soundblaster Extreme Gamer Crashing Windows 8
It seems that the soundblaster cards are currently not working with Windows 8. To be expected since this is a pre beta. But I installed the drivers for my Extreme Gamer and it was crashing every few minutes. I then reinstalled Windows without installing the drivers and it was STILL crashing every...
