No Sound from X-FI Xtreme Gamer
  1. #11
    This seems to be a problem with all X-fi cards.
    I installed W8 yesterday with the X-Fi fatality professional beta drivers, which I guess are the same for both card. (somewhere around june 2012).
    The workaround of BunnyJ works good as hell, and I appreciate it a lot (I was going to open the pc, plug off the card and use the integrated one, but I would miss my ps3 sound ;()
    The reg key, I guess it will reset all the sound config, right? That's not good. I changed the line-in to microphone, unmuted the optical and activated Crystalizer.
    I think that is faster to simply swap modes two times than configuring the stuff everytime I boot. or am I wrong?
    If the reg just activate the sound without having to configure all again, would be good.
    Thanks.
  2. #12
    windows 8 pro
    The problem with all X-Fi Cards under windows 8 is that Console launcher can't save your settings every time you reset your system, there's a solution that I' tried it
    on my X-fi XtremeMusic and actually worked, just google "PAX MASTER PCI XFI ALL OS Driver Suite V2.35 Default Tweak Edition" , with some luck you'll be at the forum from PAX Drivers...
  3. #13
    Tried that driver suite, but no luck (My card is PCIe and not PCI and the PCIe edition of PAX is for Titanium).
    Anyway, I have a better fix:
    Do you guys have hibernation? I see on many forums that the problem is SSD related and no, Is just hibernation related. And because we the SSD users have hibernation off...
    The problem is the way Windows 8 saves the config when shutting the computer.
    If you activate hibernation, configure your card and the shut down (not reboot), the config will be saved. Then you can disable hibernation again, reboot, what you want.
    I guess that if you want to change more options, you will need to do this again. Anyway, better than nothing.
  4. #14
    Window 8/Windows 7 Dual Boot
    Not sure if we're not supposed to link to them, bu the PAX drivers are located here:
    New Official PAX MASTER PCI XFI ALL OS Driver Suite V2.35 Default Tweak Edition - Discussion
    Going to try them now.
  5. #15
    Windows 8 Pro x64
    This is what has worked for me for my Xtreme Gamer and W8 Pro x64:
    Install the Creative beta driver
    Make whatever changes you want in the Creative Audio Control Panel
    Put the computer to sleep
    Wake the computer from sleep
    Shut down the computer
    When you start the computer, settings will have been saved and the sound will work.
  6. #16
    Windows 8.1 64 bit
    Xfi 5.1 surround does work fully with Creative Windows 8 beta drivers
    The other software add on items mostly dont
  7. #17
    Windows 8 x64
    Spent all day uninstalling, reinstalling, researching. That did it. Thanks!
    Quote Originally Posted by Wayward View Post
Page 2 of 2 FirstFirst 12
The Creative Sound Blaster X-fi Xtreme Audio card works fine in Windows 8. The drivers for Windows 7 work without any problem and the Creative updater and control panel also work as they should in Windows 8. The drivers can be downloaded here for the X-Fi Xtreme Audio card - Creative Worldwide...
PC infected with XTreme Rat
Hi, I recently installed AVG on the family computer and ran a virus scan, which came up with a few problems. The biggest one was that the computer was infected with the XTreme RAT trojan. This has been removed, but looking at the capabilities a RAT gives I would like to see what damage has...
System Security
Anybody still using x-fi xtreme gamer on windows 8.1 ????
Hi, i'm curious if anybody is still using their x-fi xtremegamer soundcard on windows 8.1 OS. I really wanted to dump it and use my onboard realtek ALC892. But, the audio to my surprise was inferior. Odd that a card I acquired in 2008 still beats out a modern onboard sound solution even...
Drivers & Hardware
Xbox live gamer tag
My gamer tag is not associated with my main Microsoft account that I use. It seems like a big pain to have to create a whole new user and switch to it in order to use the xbox live app. Does anyone know if there is anyway to log into a different Xbox live gamer tag than the user account you are...
Gaming
Soundblaster Extreme Gamer Crashing Windows 8
It seems that the soundblaster cards are currently not working with Windows 8. To be expected since this is a pre beta. But I installed the drivers for my Extreme Gamer and it was crashing every few minutes. I then reinstalled Windows without installing the drivers and it was STILL crashing every...
