Realtek AC97 audio driver (not HD driver)
  1. #11
    Quote Originally Posted by easyq View Post
    Having similar problems, windows 8 installed a ton of updates and suddenly i had no sound anymore. It tell me there are no speakers attached while they are still there and no i did not reconnect them.
    Stept taken so far:
    reinstalled drivers with compatibility for windows 7 - no result
    set the main .exe file to compatibility windows 7 - no result
    uninstalled all audio drtivers and rebooted hoping windows would reinstall proper drivers - no result
    checked in the BIOS and changed the HD output to AC97 - no result
    now downloading Realtek AC97 drivers hoping this would fix - result to be updated EDIT No result either
    sorry to revive this old thread BUT your ASUS M4A785TD-V EVO motherboard does NOT use Realtek HD Audio, easyq. According to the specs on the ASUS web site, it uses VT1708S 8-Channel High Definition Audio CODEC (as in VIA VT708S from VIA Technologies Inc). In other words, you installed the wrong driver. You should install the VIA audio driver, not the Realtek audio driver for your board.
Page 2 of 2 FirstFirst 12
Latest Realtek HD Audio Driver Version for Windows 8
Latest Realtek High Definition Audio Codecs 6637 Last Updated: September 13th 2016 DRIVER VERSION: 6.0.1.7936 (32-bit and 64-bit Windows) Download at: Microsoft Update Catalog
Realtek HD Audio Driver stops working when comp sleeps.
Hello, I recently got a set of 2.1 HiVi Swan M-10 speakers and hooked them up to my laptop until I can finish my build. When I first hooked them into my E55-A Toshiba Satellite the bass wasnt coming from the sub in fact it was combining into my L/R speakers making them sound terrible. A quick...
Realtek HD Audio Driver(Windows 8.1 version) Issue
Recently I decided to go ahead and update to the Windows 8.1 version of the Realtek HD Audio Driver. I procrastinated because it told me I'd have to uninstall the original audio driver and I knew it would take a while to do everything needed. It didn't help that after uninstalling the original...
Realtek Audio Manager Driver Turns Off After a While
Whenever I use my computer, if I don't play any audio on my computer for a certain period of time, and I have to restart the computer. It's really annoying because I like to view Facebook and Tumblr for a while before I do something such as playing Team Fortress 2. Is there anything I can do...
Realtek or AMD Audio Driver
What would be a better option for a Sound Driver? I used to have "Realtek High Definition Audio Codec" when I used Windows 7, but a few months ago I installed Windows 8.1 and just kept the generic "AMD High Definition Audio Device". Haven't really noticed that much of a difference. That's why I...
Win8.1+Realtek HD audio:Win driver or R2.71 ?
Hello My MB has ALC898 audio chip. Should I stay with the default Windows 8.1 HD audio or install the driver from Realtek (which is R2.71 the latest version) My system is used for gaming BTW. Thanks.
Realtek HD Audio device driver
Thanks for anyone, who helps me :D I have "an old fashion motherboard,, with realtek's VT1818S High Definition Audio 8-Channel soundcard build in to the Asus m4a77 motherboard. Usually with W7 windows i had to install the driver from asus's website... so far when i get to the installation point it...
