Audio loss after X amount of time?
    I recently did a refresh of win8, not by choice but I was getting BSOD on boot after a bad install of nfs+ paragon .
    Anyways I reinstalled almost everything but I have this problem that I notice as a audio problem at first but seems to be much bigger. I will open a video on youtube say, the video will play but there will be no audio. I go to open the audio control panel or anything pertaining to it, the window for it will either freeze or refuse to open at all. Aside from that, after I noticed this or even before I notice this I also can't open up most apps, noticeably steam games, they will start too load but then freeze on load. No Idea what is causing this and I don't know what else to upgrade driver wise. Very fed up since the refresh could have been avoided in the first place...
    This is more than an audio problem. Suggest you consider reposting on one of the other forums. The "General Support" may be a good place to start. There is obviously OS problems.
    This sounds like a OS registry issue and nothing to do with your drivers... Check for system registry errors... Back in the days of XP these could easily be fixed by changing the text in the corrupted file... now I'm not so sure... It may be time to wipe your hard drive and reinstall...
Realtek HD Audio only shows one audio output at a time
Is this a normal amount of partitions?
So my computer likes to crash normally or stop playing any sounds, so I wanted to back it up and then factory reset it and see if it fixes both problems. I downloaded macrium and saw a lot of partitions and I'm wondering if it seems weird and which ones, if not all, I should choose to back up. ...
Real time audio handling - not capable - Lenovo E531
Hello.. After using pc for some time after boot, when im playing music or watching videos, there's a weird cracking sound every couple of seconds, like the pc can't keep up or something. I tried using older and newer bios but nothing changed. I pulled this log of LatencyMon. Can you please take a...
Performance & Maintenance
No Audio coming from speakers and headset at the same time
Hello, I just bought a new pc and received it today, and i plugged my headset in to check if i hear audio from both speakers and headset but its not working. When i plug my headset in i only hear audio from my headset and not the speakers. Ive been googling and found something about it but with...
rediculous amount of errors
I installed windows 8.1 just over a month ago and ever since then i have been getting this weird stuttering problem. I notice it in games the most, but it does happen at the desktop. I have been trying to figure it out for awhile now. I have updated my drivers, updated windows, and tried some...
BSOD Crashes and Debugging
Full amount of ram not available
Hello, Haven't needed help from you guys in a while. I'm even using windows 8 now. Your advice was so good the last time.. I'm back. Ok so I have a brand new kingston 4gb ram chip installed on my ecs p-45-t black series board. It replaced a 1gb chip. My other chips all say 1.8v this new one...
Audio sound loss
I have been playing music and watching movies on my Hp pavillion g6 intel core i3 laptop player without any hitch for the past 3month,its pre-installed,the problem now is that,it is playing without audio sound,i navigate to setting,and click on volume icon,it read "DISABLED",and again"No audio...
