Sound doesn't work after installing Win8
    Hello everyone,
    I have an old Toshiba notebook here, that has always had WinXP Pro installed.
    Lately, I have installed Win8 Enterprise on it, but now the sound doesn't work anymore. I have tried downloading the official drivers from the Toshiba support site, but they don't work.
    Toshiba Satellite Pro A120
    Model number: PSAC1E-04X01GDU
    Windows 8 Enterprise 32-bit
    Doing a google search for Win 7 and Win 8 drivers, I didn't come up with an official Toshiba site. I got driver lists from non-Toshiba sites. This suggests it may not be supported by Toshiba for Win 7 or Win 8. If this is the case you are going to have to try the non-Toshiba sites until you get a driver that works.
    One other thought, if you find a motherboard chipset driver, install that first and then the sound driver.
    Maryland USA
    Have you been installing the windows updates?
    If not, please do so.
    Your driver may be in the updates...
Pin to Taskbar doesn't work
At first it work fine but when I unpin and tried to pin to taskbar again it didn't work. The options available, I can select pin to taskbar but it didn't appear in taskbar(No.3 in the screenshot). You can see in the picture, the option in No.1 work fine, I can select to pin/unpin but not work as...
No sound on start-up, Win8 needs time to output sound
Downloading 8.1 doesn work
I keep getting a message to download 8.1 but I click to d/l and it tells me I can keep on working and it will let me know what to do next..... nothing happens. Tried twice.
Performance & Maintenance
WindowBlinds doesn't work
Just in case anyone is curious, WindowsBlinds, the new version 7+, does not work. Not only does it NOT change the display, more seriously, depending on the theme you select, it totally hoses up the display so that all you get is a black screen with a mouse cursor. I was trying this because my...
Software and Apps
GPU Sometimes Doesn't Work
Hey all, Not sure where to post this so thought I would try here. Ever since I've put together my new PC I have had an issue with my wireless card. Sometimes when I start up my PC the driver doesn't load for it, I can see it in the device manager list but the driver hasn't loaded and when I...
Graphic Cards
WIN + Tab doesn't work but ALT + Tab does
WIN + Tab doesn't work but ALT + Tab does Has anyone else observed this?
