personalization sound
lorrry
In personalization sounds "play window start up sounds" this is grayed out cannot check or up checked I do not know what the problem is if anyone has an answer. 660 inspiron window 8.
    window 8
    dell HWJKNV1
    nydia
    internet explorer
    nortons
Are you on a system with multiple users?
Are you on as administrator? Or is someone else the administrator? You may not have rights to change that.
Is your sound card working?
Are there any exclaimations in your device manager?
Do you have a sound scheme seleted or is it set to no sound, change sound scheme and hit apply and see if the box is now available.
Brooklyn
    HP G60
    3 GB
    Nvidia GeForce 8200M G
    1366 x 768
    Chrome and Chromium
    Avast Free & Malwarebytes
I am the administrator. I changed sound schemes there are only two or 3 that is all. nothing happened. I checked device manager they were all working. my husband uses the computer he has a password. His side is the same as mine. the play windows startup sound is grayed out. thank you
    window 8
    dell HWJKNV1
    nydia
    internet explorer
    nortons
Ive disabled my sound drivers but my [ ] Play Windows Startup Sound still works, but my > Test button is grayed out, is your test button grayed out as well? or Just the Startup sound box? Im trying to duplicate your issue..
What are the sound drivers called?
Does it just say HIGH DEFINITION AUDIO with no brand name?
i
Brooklyn
    HP G60
    3 GB
    1366 x 768
    Chrome and Chromium
That is why it is not allowing you to "test" the sounds - The actual sound drivers must be installed, active and working.
Pull up your Control Panel-Hardware and Sounds. Go to your SOUND.
DO you have an active device? It will have a green checkmark.
    AMD 4400+/4200+
    2 GB/3GB
    GeForce 8400 GS/GeForce 210
    Hitachi 40" LCD HDTV
    "1842 x 1036"
    WD My Book 1140 USB Device
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Microsoft Intellimouse
    Cable Medium Speed
    Chrome/IE 10
    Eset NOD32 6.x/Win Defend
Lorrry, Ive tried everything i can think of to replicate your problem, but no matter what I disable that checkbox always remains available to me.
Ive even created registry changes to deny me access to the sound scheme, but no difference. It always works..
Ive searched scores of websites including Microsoft to no avail, many have this problem going back to Win XP, but no solution.
It looks like its just flat out not an option in your windows version, or you are denied access.
What is your windows version? Pro or Pro Media center?
If youre willing to try one more thing, lets start the computer in SAFE MODE WITH NETWORKING,. and tell me if its still grayed out.
Ill keep looking, the answer is out there, its just buried..
Brooklyn
    HP G60
    3 GB
    1366 x 768
    Chrome and Chromium
This may have something to do with it.
Or not:
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
Medab1 that was the case in my instance, i was switching back and forth so much i forgot to select a sound hence the grayed out test button. Thanks for looking out.. :)
But in her case its the actual [play windows startup sound] box that is grayed out.. its very strange...
    HP G60
    3 GB
    1366 x 768
    Chrome and Chromium
Lorry, I just found a previous message from you on this forum stating that your Audio services would not start, is that still the case with your current problem or was that another computer?
Ive disabled my audio services in my last post but that did not gray out my logon sounds box either..
    HP G60
    3 GB
    1366 x 768
    Chrome and Chromium
Yes.Very odd.
Maybe somebody will provide an answer.
EDIT--
Running:
in elevated (administrator) command prompt might fix it.
It's worth a try.
It takes a long time to run.Half an hour or maybe more.
Restart after it finishes.
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
