Sound is extremely quiet?
    So I am wearing headphones, they're plugged into a 3.5 mm speaker. This speaker is plugged into my computer's motherboard.
    I can hear sound, but it's extremely quiet. My speakers are maxed out. Windows 8 sound is 100%. Youtube video is at 100%.
    I honestly don't know how to update my drivers any further. I have a M2N-SLI motherboard. I went to the ASUS website, and there isn't even a Windows 8 option for it.
    I also have a creative soundblaster Xi-Fi extreme audio sound card. Using the CD it came with, I tried installing the drivers again, restarted the computer, and nothing changes. I can't find the drivers on creative's website either. I tried every 3.5 mm jack in the back of my computer and nothing works.
    All the contacts are in. I tried using other speakers (and headphones) and had the same issue.
    i'm at a loss.
    If I hover over the little speaker icon in windows 8, it says "speakers (USB): 100%" Does that have anything to do with my issue? I am not using USB at all.
    edit: under Device Manager, all of my Audio inputs and outputs are up to date and working properly
    edit: SOLVED. didn't have my sound card set to default
Realtek HD Audio Really Quiet (Sager NP9377 W8.1)
I have a Sager NP9377 Laptop that has Realtek HD Audio. I have noticed that audio seems really quiet. I usually have Speaker volume at about 28% and it sounds quieter than it should at that level. Is there anything I can do to fix this? Thoughts and help appreciated :)
Quiet and Choppy Sounds (Mostly in games)
Hi everyone, I started having an issue with my sound two days ago; I first noticed it on a game called League of Legends when the SFX on the buttons started to sound quiet and glitchy, then when the champions started to sound quieter than they should, a few even echoed. I reinstalled League of...
Quiet Hours - Enable or Disable in Windows 8.1
How to Enable or Disable Quiet Hours in Windows 8.1 Notifications during Connected Standby and their auditory alerts may be disturbing to some users, particularly in the evening and late night hours. Windows 8.1 introduces Quiet Hours to suppress notifications and help save battery power....
Sound is very quiet and will change sometimes
Ok first thing is that I've already been looking for a solution through google and I did come across this: I changed it to what the picture shows and my volume is still very quiet. I've also checked if my drivers were up to date and they were. The strange thing...
Windows 8 Mic really quiet
Hey! I recently got windows 8 64 bit and after installing the audio drivers my mic is very quiet (literally not audible in any program). When I uninstalled the audio drivers it worked again (I have a msi motherboard and got the realtek driver on their website), but not in every program. Skype (I...
Cool n' quiet - Overclocking AMD 955 BE (MSRPhenomTWKR alternatives??)
Hello all. okay so i run my system with my 955 BE clocked at 4.0 Ghz (210x19) and 1.4250 Volts and have ALWAYS used MSRPhenomTWKR to set custom cool and quiet states while overclocked so that my system would idle at 800Mhz and draw less power and keep it below 30'c. however with windows 8,...
Drivers & Hardware
Its a bit quiet in the forums atm... and no new news lately it sux I recon.
Chillout Room
