window audio in services
    I found windows audio in services but cannot get it started it has a connection with window endpoint service in services which also will not start
    Lynnwood, WA
    Windows 8, Windows 7
    Can you explain in more detail what you're actually trying to do? I don't get what the significance is.
    my sound in windows eight works sometimes and not other. In personalization I cannot get the startup sound to work. I wet on services and found there are2 services not working
Realtek audio, Gigabyte mobo: muffled audio, no mic input
Services - Restore Default Services in Windows 8
How to Restore Default Services in Windows 8 and 8.1 This tutorial provides you with registry downloads that will completely restore any of the default services and their settings you want in Windows 8, Windows 8.1,and Windows 8.1 Update. This can be handy if a service was deleted by mistake, is...
Window doesn't open full screen when hover over IE window
I have a Lenovo N580 laptop. Last week, I had to do a factory reset (with help from Lenovo Tech Support) because of compatibility problems with new software from my employer and windows 8.1 which is actually worse than windows 8. The compatibility problems caused my screen to go black. When...
Audio issues (Static + crackling) and high audio latency
After having my motherboard, graphics card and RAM replaced due to a power surge, I have been experiencing high audio latency, along with very poor sound quality which includes static noise, crackling. The sound is similar to that of an untuned radio. The sound...
audio driver for window 8
I have window 8 I have speaker sound but no window sound. I tried to find if I was missing a driver. on sound video I have smart audio, itel display audio and NVidia high definition, On audio I have Conexant smart for speakers I do not know if I have an audio driver missing. but I I have...
Drivers & Hardware
Audio Alerts Disrupt Java Audio While Live Streaming
Window 8 Build 9200 RTM After Window Update Some Icon Missing
Hi , My Window 8 automatically Window Update and now some of the icon missing :huh: Anyone encounter this and possible to fix this ?
