Recorded sounds are auto adjusting. Help!
    When i try to record from my sound card the volume will randomly go up and down when i try to replay it.
    When I try to record from my microphone in the microphone input port it gives an odd problem. Whenever I sustain a note it begins to record just fine but after about 2 seconds the volume adjusts down to about 20% of the original and continues to record. It does this in multiple sounds recording software programs. I have skype turned off and no other microphones hooked up. In the communications tab of the sounds menu I have set it to 'do nothing' but this had no effect. It seems like there is some sort of auto volume leveling thing going on but I cannot find where it would be. I have an HP desktop with beats audio not sure about the sound card otherwise.
    Any ideas?
    Beats audio adds various "enhancements" to the basic sound card.
    Check the Control Panel to see if you have an Enhancements panel for the sound that includes items such as Echo, Reverb, auto adjust, etc.
    I do a lot of audio work, as I have a computer based recording studio (using Sonar X2 software).
Recorded TV does't update after awakening
This seems to be an ongoing problem since Media Center was first released. It was a problem in NT, Vista, 7, 8 and now in 8.1. I have the Recorded TV library including folders on another computer. When Media Center starts and for as long as it is running, any programs added to the folders on the...
Windows Media Center - Watching recorded shows on TV
I just bought the Ceton infinitv 6 ETH. I have everything working great on the PC. I am using WMC as the "set top box" in an effort to get to a point where I can return the FiOS STBs I rent. My next problem is getting to watch live or recorded shows on my TVs. I know I can get Xbox 360s as...
Software and Apps
Windows 8.1 Sounds. Appears some .wav sounds are missing
Just set up my new Dell 660 desktop and noticed that with Windows Default sounds that the "navigation compete" sound effect and some others don't seem to be working. That one sound I mention is the familiar sound you get when using IE and clicking the mouse to navigate around the web pages but...
Music Playing On Winamp Auto-Lowers When Other Sounds Play
I listen to my music on Winamp, yet when I'm using any other program that plays some sound effect (for example, playing some online game on Google Chrome), every time the game makes a bit of a loud sound effect, for a second or so, the music lowers itself for that second, then goes back to its...
Picture preview in WMC for recorded tv ruining Sports
Surely I'm not the only one to have a game I'm about to watch completely ruined by seeing a picture preview of a winning player being interviewed in the post game. I would think there would be an army of ticked off sports fans in an uproar to fix this but surprisingly Google search has yielded...
Software and Apps
Windows automatically adjusting sounds
I just built a new gaming PC with windows 8 and an msi z87 g45 motherboard. It's amazing, and I installed the Soundblaster and realteck Hd drivers. :D The only problem that I'm having is that every time 2 things play at once, the other's volume is lowered. like when Im playing battlefield 4, my...
Strange event recorded.
What does this mean. ESENT 910 Performance svchost (1280) The database cache size maintenance task has taken 60 seconds without completing. This may result in severe performance degradation. Current cache size is 9 buffers above the configured cache limit (190 percent of target). Cache size...
Performance & Maintenance
