Realtek Sound issues?
    I did search-no luck. Sound was fine yesterday-no changes by me or win update.
    If I re install the realtek drivers sound is fine-as soo as I reboot the sound is gone???
    Same thing everytime?
    Any ideas?
    Please fill in the "My System Specs" so we can better try to help you.
    Has this ever worked OK? or is it a recent problem?
    I do not believe my system specs will help. On board sound chip stopped working out of no where.. The reboot process seems to be disabling the service -every time. Very Strange. I can install the drivers, start the service and all ios well. Untill the next time I reboot. There is one difference actually-Windoews Defender , I turned it on but I do have real time protection shut off. Just in case I needed it to run a scan because I can update the defs.
    This is extremely weird.
Updating Realtek I lose sound effects tab
Below are the pics when I use the version from my motherboards disc. If I update to any newer version, the sound effect tab disappears. Probably something simple to fix but I went through all the settings it's still gone. I tried installing the latest version from the MSI website, and using the...
Windows Realtek Audio Popping Problems (Realtek ALC662)
Realtek PCIe GBE Family Driver Issues and Internet Speed
Ok .. well it is pretty simple, maybe. I have found that my internet sometimes slows .. to like 5 Mb/s, where normally it is around 18 Mb/s. The solution .. to uninstall the Realtek PCIe GBE Family Controller Driver from device manager and reboot. My internet .. all of a sudden goes back to the...
Drivers & Hardware
Realtek audio issues
So I've been having issues with the Realtek HD audio drivers on my Sony VAIO laptop (model number VPCCW21FX). No matter what version of Windows I use (Windows 7 or 8), the Realtek Audio Manager will not open. Currently, I am running Windows 8.1 x86 on my laptop. Before, I was using the Microsoft...
Sound issues
As of recently, I have noticed my sound will randomly just stop. There's first a brief half-second of a static-like crackling and then a few "pop" noises. It will then stay muted for anywhere between a few seconds to several minutes. However, using my Creative software (either Creative Console...
Realtek Audio installation issues
I recently upgraded my PC (Foxconn motherboard) to Windows 8 and downloaded what I understand to be the latest Realtek high definition audio driver ie The driver happily installed but at the moment is a bit reluctant to make an appearance among devices listed in the Device Manager. ...
Realtek HD Audio and 5.1 sound problem with Windows 8
Hi, I have already done a search on this forum to see if anyone has been having a similar problem and many do, but so far no suggestions have helped me...... My problem is I have an Acer 6920G laptop running Windows 8 (and 7 on another drive) and no matter which Realtek audio drivers I use, I...
