Text to speech engine not working
    Win 8 Pro
    For some reason, It will not load or play the voices.
    Win 8 Pro on a HP G7 laptop w/8GB ram
    All appears to be there but it won't read aloud and says it can not install the voices. I have checked everything I know to check but nada.
    My sound works on all other things but text to voice. It says it can not play the voices and to try another audio device...
    I am using my laptop speakers.... any help appreciated.
    Sloe Deth, Californicatia
    Is there a setting to turn your laptop Mic on and off? A switch? Or something in the Mobile Power Settings? Open Control Panel and open your Sound Hardware, see if the Mic is present and turned on. Also, under Speech, make sure you have the right Speech Profile loaded.
    Windows 8.1, 10
    Just to double check... are you using the built-in Windows 8 feature or text-to-speech software within another app, (for example I think something like that was built into MS Office)?
    If you go to the Start Screen, search for "Narrator" within All Apps and click it, what happens?
    Win 8 Pro
    Hi and thanks for the reply....Let me start over. Windows 8 Pro HP G7 Laptop
    I am trying to use the Text to Speech. In the CP, I see the check box (checked) to use it. I also see the 3 voices listed that came with win8Pro. I select each one, one by one and they all say the same thing;
    can not play the voice, select another audio device is the installed speaker Hp> IDT HD codex
    Those are the only options available in Win 8 on HP laptop. I have no other sound problems.
    For some reason the voices do not load or play, to even test them.
    I am going to use Naturalreader ( A text reader program) as I am an editor and proofer for a magazine.
    Thank you for any help on this.
    Windows 8.1, 10
    So when you refer to the option from Control Panel, do you mean this screen?
    (I got there by going to the Start Screen and searching for "Change Text-to-Speech settings" within Settings)
    If you click on Advanced do you get the option to change which audio device you're using?:
    By the way, did you try the Narrator?
    Win 8 Pro
    Hi DavidY
    Yes and yes and yes. The voices will not play at all. It seems that they do not load or are not actually installed even though they are appearing. Or they can not play on my laptop speaker setup..... I only have 1 audio output option and it is the Speaker Hp IDT HD codex
    Windows 8.1, 10
    Hmm - it may take someone more knowledgable than me I'm afraid.
    Can you post a screenshot showing the error message you get (and what's behind it)?
    Are you using Narrator in Windows? That's how the text to speech feature works. I don't know if that is something that needs to be said....
    Also, I'm glad to see that you use text to speech, I had that great idea to use a long while ago to proofread!
Text suggest not working, even though box is ticked 'yes'
In all the instances I've found, the text suggestion feature on the touch screen keyboard is missing on my Linx 10.1 (windows 8.1), I'm almost certain it WAS there originally because I was speedily typing on it, but now it's stopped, or I've done something without knowing. The box is ticked "yes"...
Drivers & Hardware
Text to speech programs w/ word highlighting you tried?
Software to read and highlight text as each word is being I've tried a few like SpeakIt in chrome. I am trying to find something like this that is free or doesn't cost as much The program...
Software and Apps
IE 10 stopped Working error / Search engine not working
Hi! I am repeatedly getting the error "Internet Explorer not working" / Windows checking for solution/Last browsing closed unexpectedly , then Restore Session. I went to google to find a fix for this error .I'm being told to Press Window + W key then type in Troubleshooting in the Search box , then...
Browsers & Mail
"Text Only" print driver no longer working?
For many years, I've used the Generic / Text Only virtual printer driver to convert Web pages and other files to plain text with minimal formatting, but the last time I used it, the resulting file was peppered with unnecessary spaces, making it close to indecipherable when viewed in a text editor. ...
Text to speech toy
With this vbs script you can type whatever you want & then hear it spoken: 37996 Just something to play with. :) *********************************************************** Dim msg, sapi msg=InputBox("Enter your text for conversion– ","David_Speaks")
Microsoft working on Excel natural language speech input
Read more at source: Microsoft working to bring natural language, speech input to Excel | ZDNet
Windows 8 News
Text to speech not working
Text to speech is not working at all. I use Mumble and it is very important because I run the server. I checked the text to speech settings in windows, and mumble. When I hit "Preview" In either one, it highlights the text, and I hear nothing. Sound is coming out, just not text to speech. If anyone...
