Headphones Not Working...
  1. #11
    Windows 8 Professional 64 Bit
    think that the problem is the driver....Ask me information about my computer if you want > so that you will give me the correct driver to download
  2. #12
    Hi, I am having the same problem with my headphones. When I had Windows 7 on last night it worked perfectly and today after installing Windows 8 they stopped working. Everything sound comes out of the laptop speakers. I have tried putting them in different ways into the jacks and then also tried an ordinary set of headphones no mic and still the same thing happens. Please help
Page 2 of 2 FirstFirst 12
Headphones not working after uninstalling a sound program
The program was Realtek HD. I installed it, it was trash, so I uninstalled it. Now that I've booted my PC up again, headphones don't work. Tried multiple headphones so it's definitely the drivers. Currently I've reinstalled the infernal program but would like to uninstall it while keeping audio,...
Drivers & Hardware
Headphones not recognized
Hi, my computer doesn't recognize my headphones. The speakers work fine, the headphones work on other devices. They used to work on this pc too, but a few hours ago my friends and I were trying to record something with a mixing table and they had to change a few things for it to work. I have no...
Headphones not working on Acer Aspire 5820T-6825
I upgraded to Windows 8 and now I noticed that the headphones won't work. First I followed some troubleshooting that concluded on uninstalling the audio drivers including some Intel version of the driver and then when I rebooted then the sound worked. Now it happened again and I really don't want...
How to use the StereoMix and Headphones mic at the same ?
I need to use StereoMix and my headphones built in mic at the same time. The problem is IF StereoMix is enabled, only the PC's internal Mic is activated. I cannot activate my headphones mic unless i disable the StereoMix device first.
No sound with headphones?
Hey guys, I have the consumer preview Windows 8, No problems with sound initially until i plugged in my headphones. No sound at all, at first i thought the headphones where broken so i tried 3 other pairs of earphones and still nothing. Anyone have any ideas as to whats going wrong?
"headphones setting not working
I have been using windows eight for about 6 months now, and suddenly the "headphone" setting for audio does not work. I tried plugging my headphones into the integrated audio in the back, and it worked from the "speakers" setting. Whenever i plug my headphones into the front audio header, any...
No sound thru headphones
On my home-built PC with dual-boot XP and Win8 RP, I can't get any sound thru headphones connected to the tower case's front headphone jack. I get sound through the speakers built into my display, which is connected to the mobo on the case rear panel. Sound comes thru headphones fine in XP. ...
