HELP no sound in windows 8, now not even booting.
    Hi i have the following
    BioStar Hi-Fi A85W Socket FM2 Motherboard - ATX, Socket FM2, AMD A85, DDR3 2400 MHz (O.C), SATA III (6Gb/s), RAID, 8-CH Audio, Gigabit LAN, USB 3.0, PCIe 2.0, CrossFireX Ready
    AMD A8-Series AD560KWOHJBOX Quad-Core A8-5600K Black Edition APU - 4MB L2 Cache, 3.6GHz, Socket FM2, Radeon HD 7560D (256 Cores), Dual Graphics Ready, DirectX 11, Fan, Unlocked, Retail
    Kingston HyperX Red KHX16C9B1R/4 4GB Memory Module - 1600MHz, 9-9-9, DDR3, CL9, 1.65V, Unbuffered
    Toshiba HDKPC03 DT01ACA100 1TB Hard Drive - 1TB, 7200 RPM, SATA, 3.5"
    Window 8 64 bit.
    I recently put this computer together as a cheap media machine. Everything worked. It connected via onboard NIC to the internet, it had sound. No problems.
    Then I upgraded by adding another stick of RAM. Same module 4gb. and all hell breaks loose.
    I lost lost and internet. Media sound service couldn't start. Said something along the lines that found new hardward. And it wasn't communicating with my NIC card anymore.. I tried updated the drivers. No joy.
    I contacted Biostar and asked for an issue. They recommend me to update drives and then reset bios setting to factory defaults. I tried that. No joy.
    I then RMA's the vendor and got another mobo. Installed it and it had the same issue. No sound no internet.
    Last nite I decided maybe I should just reinstall windows, but now my computer freezes on the bios screen.
    I used to have a full head of hair. Please help.
    Thx, Tikki.
    This is no longer a "Sound" problem. Its a hardware/installation problem.
    My recommendation is to repost on the appropriate forum section. Installation & Setup - Windows 8 Forums
    Remove the extra added memory stick and see if issue still remains. If not, then you know you have a faulty RAM stick. Have you seen or experienced any BSOD's?
    You can rem Memtest86+ to test your memory.
    Memtest86+ - Advanced Memory Diagnostic Tool
mobo sound and HDMI sound not synced in Windows 8.1
No sound on start-up, Win8 needs time to output sound
Samsung np-355vc uk sound drivers installed, but no sound?
No sound windows 7 - restored to 8.1 - still no sound.
Had windows 7, sound worked for quite awhile with my toshiba laptop. Installed the realtek driver and about 2-3 months later the sound stopped working. When plugged into TV w headphone jack it works (at least the last time I did this). I unplugged and the sound worked again for about 2 days and...
sound on solitaire turned off but still loud sound
Booting problem with dual booting with windows 8 and 7
Recently I purchased a laptop with windows 8 64 bit pre-installed in it. For my job purpose, I needed windows 7 32 bit. After searching the web and also using the information I got from this site, I disabled secure boot, deleted the recovery partition and converted GPT partitions to MBR. Then I...
DUAL BOOTING PROBLEMS- booting win8 with win7.
Okay, so ive tried many ways, and Ive finally got stuck with using a VHD. I have followed countless tutorials, and finally found one. (on this forums somewhere) I go through all the steps, and it seems like it is working, and then when I boot my system it says this,...
