annoying usb connect and disconnect sound
excaka
just bought a new computer with windows 8. ever since its a non stop sound of the usb being disconnected and connected. anyone have this problem? im about to throw my computer against the wall :mad:
    i7 3820
    sabertooth x79
    16gb corsair dominator
    amd 7970
    WD 1 TB
    corsair ax860
    haf xb
    h80i
    corsair k70 m blue
i seemed to find the sound in the sound settings. its the device connect/disconnect. how do i disable the sound?
    i7 3820
    sabertooth x79
    amd 7970
    WD 1 TB
    corsair ax860
    haf xb
    h80i
    corsair k70 m blue
    W8 Inspiron 17R W8P+MCE HTPC
    Custom HTPC systems builder, trouble shooter for Apple and PC products.
    My HTPC specs:
    Core i5 W7 Pro/W8 Pro+MCE
    Lian Li blk mid tower 10 gigs + 2 OS HDD's W7/8.
    Gigabyte UD3 mobo P55 chipset.
    Workstation:
    Same as above but using the "M" series mobo with ATi 5670
    Dell Inspiron 17R i3 3rd gen W8.
    Nokia Lumia 810 W Phone8.
Mine does this here and there. I have noticed the cold air causes the metal in my usb ends to shrink. It is the weirdest thing. So they don't fit tight like usual.
    i7-860 Lynnfield 2.8GHz
    Asus p7p55d pro
    G.SKILL Ripjaws 4GB DDR3 1600 (PC3 12800) G.SKILL PIS Series 4GB DDR3 SDRAM 2200 (PC3 17600)
    GeForce GTX 550 Ti (Fermi) 1GB 192-bit GDDR5
    Sanyo LCD TV
    1366x768
    WD Green WD10EARS 1TB
    WD Black WD5001AALS 500GB 7200 RPM
    Seagate Barracuda STBD2000101 2TB 7200 RPM SATA 6.0Gb/s
    Thermaltake Black Widow W0319RU 850W ATX 12V v2.3, EPS 12V v2.91 CrossFire Certified 80 PLUS
    Thermaltake V3 Black Edition VL80001W2Z
    CORSAIR Hydro Series H55 Quiet CPU Cooler
    k120 Logitech
    MX518
    12MbDL 1mbUP
    AvG pro
    This just made me realize that my new harddrive was better then my gamedrive :/
I had the same problem. Whenever Windows told the monitor to shut off, it would make the device disconnect-reconnect chimes every few seconds and drove me nuts. Looking into the matter further, my monitor is connected via HDMI and it was an issue of the monitor's speakers disconnecting and reconnecting. To fix it, I went in to Devices and Printers and removed the HDMI Monitor Speaker device. Problem solved, since I don't use the monitor's speakers anyhow.
    Windows 7
    self built
    i7 quad core
    z77
    32gb
    motherboard issue
    waterfox
    avast
I have the exact same issue, but in win 7. It started a few weeks ago right after i upgraded to 2x 120GB ssd's in raid 0, the sounds would come randomly, and after a while, it stopped. But yesterday when i deactivated sli, i got a bluescreen of unknown reason, and after that i now get those sounds continuously when the screens go dark (got 4 screens connected, 3x dvi-d and DP-HDMI adapter)
    Windows 7 ultimate 64bit
