Windows 8 Enterprise Low Volume Help
    Windows 8 Enterprise, Lubuntu 12.10
    Hello all I am new to the forums, I generally try to Google and fix the problem before asking on any forums, but I have been searching for quite some time on this issue, The volume for media playback is way to low in windows I have tried everything from disabling enhancements, I also have installed SRS HD audio software also with low volume.
    If someone could recommend an audio booster, or anything that would boost SRS Audio output would be great or any other fix. Thanks in advance for the help.
    I also after using the default driver provided by Windows 8, updated to the newest Realtek HD driver, and still no difference.
    The first thing is to get the audio driver from your PC or motherboard vendor, as applicable. That is the preferred sound driver. If the vendor does not have a Windows 8 driver, Vista/Win 7 drivers will work OK. I'm using a Win 7 driver on my system and all the audio functions are working OK.
    Is ALL audio low or just from certain programs? If ALL are low, first thing, obvious, is do you have the system volume level up?
    Second if ALL is low, are you using "powered" computer speakers (ones with a power amplifier)? If you use a headset it ALL audio low with that too?
    Please fill in the "My System Specs" It helps us to try and help you.
Windows 8 Volume Indicator
Hello, I was wondering if anyone's tried changing the built-in Windows 8 volume indicator? I am thus far unable to find anywhere that I can make it larger, smaller or where it appears on the screen. Anyone else tried doing this? Thanks
Volume mixer becomes unresponsive when I change volume
Scanning and repairing volume (\\?\Volume...) on startup
Hello Guys, this is my first post on eightforums, i recently got a new laptop "asus vivobook" that came preloaded with windows 8. The laptop comes with a hybrid 24 GB ssd (8GB of those are for the system files,windows 8 is installed on,the remaining are in a 2nd partition for recovery) i...
Performance & Maintenance
Issues related to win 8 enterprise to 8.1 enterprise
I have 8.1 iso on a bootable usb and whenever i press the option to keep my files and settings, i get this message. I tried following it but it still appears. So i tried running the setup.exe (from the iso) when my windows is booted up, the only option i get to pick to keep something is " keep...
Installation & Setup
Enterprise RTM ==> Enterprise final 12 mins update !!
Hi there worked exactly as "It said on the tin". Ran the .exe file from the ISO (using the virtual mounter system in W8.1 (W8 has this too). Gave me the option to keep applications and settings (Didn't on RTM). Installed fine -- you need to DISCONNECT from the Internet at Ms account...
Windows 8.1 Enterprise RTM Now Available To Volume License
Windows 8 News
