How to enable disabled\unused sounds?
    Windows 7 Ultimate
    I would like to know how to enable sounds that are unused or disabled in Windows 8, for example, the shutdown sound. I've seen on another website that there's a registry tweak for the sounds to appear in the Sound control panel, but my problem is that the sounds aren't playing. Is there a fix for this?
    windows 8 x64 pro
    right-click on your desktop and go to personalize settings and there click sounds at the bottom and there you wil probably find it
Cannot re-enable disabled RealTek HD Audio
I was having problems reconnecting a bluetooth speaker for my Acer desktop with windows 8.1 OS so tried disabling the default RealTek HD Audio. Now it doesn't show up as a speaker--only my bluetooth speaker that it says is disconnected show. When I look at my device manager it is there, and says...
Windows 8.1 Sounds. Appears some .wav sounds are missing
Just set up my new Dell 660 desktop and noticed that with Windows Default sounds that the "navigation compete" sound effect and some others don't seem to be working. That one sound I mention is the familiar sound you get when using IE and clicking the mouse to navigate around the web pages but...
Remove unused LAN connections
So I've set up my desktop PC to function as a portable WiFi hotspot for my other mobile devices. First I used the Cmd Prompt to create a sharing network, but since I had to open that every time I started up the computer, I switched to using a program called MyPublicWiFi (1 click setup). ...
Network & Sharing
Secondary HDD formatted as GPT has 4 unused partitions...
Hi everyone, I recently set up Windows 8.1 on a new SSD (as GPT). While I'm aware that Windows automatically creates its necessary extra small partitions for recovery, I just realized that my secondary HDD which I also formatted as GPT has these extra partitions. This secondary HDD was the one...
Drivers & Hardware
C: wont extend with unused portions of HDD,
Currently "restored" my PC to factory settings, now currently i am UNABLE to allocate unused HDD space back into (C:) and i have no idea why :S can someone please help me with this ussue 38925
Drivers & Hardware
Services disabled? Can't enable what to do?
I installed Windows 8 on my PC works excellent I recently came across a website that stated to disable all the services on the PC and reboot which I did but things weren't working and I would like to get the services back. I went under services to start/automatic but some I get dependency or group...
Performance & Maintenance
