Sound Recorder XP
    Sound Recorder XP
    I don't really care for the current sound recorder, and I'd like the Windows XP sound recorder back because it has way more options (like echo, reverse, etc).
    Anyway, my question is: Is there a way that I can download the XP version? Windows 8 doesn't have the sndrec32 file (as far as I'm aware), and I can't find a tutorial that doesn't require it. I guess my question is... Is there a way to get the XP sound recorder on my Windows 8 computer?
    I doubt this info will help, but Just In Case: My laptop is a Toshiba.
    I don't think so. Windows XP handles some sound functions differently than Vista/Win7/Win8.
    Download the free (and popular) Audacity recording program. It has everything the XP sound recorder had Plus.
    Audacity: Free Audio Editor and Recorder
Sound Recorder XP
Best macro recorder for Win 8?
I could really use a good macro recorder. I read that some like JitBit can make the Macro into an exe. What are some good recorders both Free and commercial?
Software and Apps
My recorder picks up mic sound but browser and game don't!
So i was playing halo 2 pc when i got a voice message. Since i always use my trusty mic headset i click play on the message and it said no playback device detected and i tried fixing it with ingame options but it didn't work! and my browser doesn't either. i tried to record my voice but mic wasnt...
Sound Recorder
Good evening to all. I have an Acer Aspire i7.E1-572 laptop.Windows 8.1 Went to use the sound recorder that is included in the laptop,My granddaughter went to give a song into it and all went to plane,Played back the recording it was just perfect. Now the only hitch is where does it save the...
Does Performance Recorder work in 8.1?
I am trying to analyse boot performance using this tool on 8.1 Pro. Windows Performance Analyzer I have already updated to the latest version of ADK but after rebooting it fails. I have Windows 6.3.9600 Build 9600 and Performance Recorder version 6.3.9600.16384(winblue_rtm.130821-1623) which...
Performance & Maintenance
Sound Recorder App Shortcut - Create in Windows 8.1
How to Create a Sound Recorder App Shortcut in Windows 8.1 Sound Recorder is an app that is included in Windows 8.1 by default that you can use your PC's microphone to record audio for up to three hours per recording file. You can play back, edit and share your recordings, and use it side by...
Metro Windows Sound recorder question
Hello, I am wondering where the audio files are saved so I am able to upload them to a friends pc?
Software and Apps
Snipping Tool, Steps Recorder
Hi all, I'm running Windows 8 on a new Toshiba Satellite laptop. Every time I try to use the snipping tool, the steps recorder or the sound recorder it reverts from the screen I have open to the desktop screen. Even the print screen key doesn't work, even if I press it in conjunction with ALT,...
