Solved USB Boom mic or headset - recommendations
pcRat
Bay City Michigan USA
A friend was using voice primarily for email. His voice has gotten lower and the MS LifeChat LX-3000 USB is not picking up his voice that well anymore.
Could someone recommendation a better USB headset or boom mic reasonably priced?
Thank you in advance.
Ron
    i7-3770K
    ASRock Z77 Extreme4
    16 GB
    onboard
    17" 24"
    1 TB WD
    550w
Many PC mic inputs have a boost option to bring up the volume level of the mic input. Check the users PC to see if that is available. May not need a new mic. Unless the Microsoft mic is defective another PC mic won't make a difference. If its that bad, a regular P.A. type mic and a preamp will be needed.
Thanks for response. Mic works fine for others. Friend is down to about 10% lung capacity. What's a ballpark figure for a cheap mic & preamp?
    i7-3770K
    ASRock Z77 Extreme4
    16 GB
    onboard
    17" 24"
    1 TB WD
    550w
I just checked at TD and it's definitely out of price range but thanks again for point in right direction.
    i7-3770K
    ASRock Z77 Extreme4
    16 GB
    onboard
    17" 24"
    1 TB WD
    550w
That's about the only thing, a preamp. A different mic will be needed as computer mic's are Condenser mics and require 5VDC so it won't work with a regular preamp.
Specialized equipment for someone with a limitation is always overpriced. I'm in Florida with all the retirees and see that all the time.
Thanks for your help and clarification of the differences.
I'll just mark this solved.
    i7-3770K
    ASRock Z77 Extreme4
    16 GB
    onboard
    17" 24"
    1 TB WD
    550w
