No Sound! - win8 32bit
    I have just installed windows 8 again and now I have a problem with my high definition audio device(I had this problem before too but someone took care of it and now that person can't help me anymore o.O)...the sound doesn't work , not even a bit ( View image: no sound ) ... I tried to install some drivers but the same problem still remained (I used "run as administrator")...
    IMG Missing driver : View image: missing driver
    There are some informations about my PC, if you need more,just ask .
    Thanks in advance for your help.
    Manufacturer: ASUSTeK Computer INC.
    Model: P5GDC
    Version: Rev 1.xx
    Serial Number: MB-1234567890
    North Bridge: Intel i915P/i915G Revision B1
    South Bridge: Intel 82801FB (lCH6) Revision 03
    Name: Intel(R) Pentium(R) 4 CPU 3.00GHz
    Cpu Socket: Socket 775 LGA
    Max CPU Speed: 3600MHz
    From what I can tell, it looks like the ASUS supplied sound driver is not installed?? If this is the case, install the ASUS sound driver and see if that fixes it.
    By the way, according to what I see on the ASUS site, this motherboard will support 64 bit OS.
    I can't find what I need on the asus site....please help me , I am a little bit noob at this kind of things. I uploaded pics with more informations about my pc,here : / gallery - 1, 2, 3, 4, 5, 6, 7 .
    I don't see any sound drivers on the ASUS site for Vista 32 bit (that is the newest OS they list). If the hardware (sound chip) is compatible Windows would have installed the basic function HD Audio Codec drivers and you would at least have basic PC sound.
    Sadly, it looks like this motherboard may not be Windows 8 compatible, if Windows has not installed any sound driver.
Updating 7 year old PC from Win7 32bit to Win8.1 64bit
The CPU is an old Core2Duo that supports 64bit This computer meets the minimum requirements listed for Windows 8.1 and the upgrade assistant tool says everything but safeboot will work (which im fine with) My concern is taking a computer that has been running 32bit for 7 years and making it run...
Installation & Setup
Enable Direct3D acceleration for 32bit apps in Win8.
Hello, Now I know that this issue has been discussed much around the web but most of the solutions focus Windows XP and/or are outdated. Some suggest updating video drivers, some say editing specific registry keys that don't exit in Windows 7/8, while others don't reply. So I'm posting here in...
Performance & Maintenance
How to convert from Win8 32bit to Win64
Hi, I already bought and installed Windows 8. I have a i7 laptop with 64bit proccessor but somewhat the company decided to pull it out with win7 32 bit OS. When I upgraded to win8 I wanted to switch to 64bit but didn't find the option for that during the installation proccess. Can I do it now?...
How to enable Memory (RAM) usage in Win8 32bit?
Good day masters! Hello Guys.. I'm wondering on how to enable my 4GB Memory Ram on my Win8 32bit? When I check my system info.. 4GB(2.92 usable) is anything here knows how to enale all 4gb memory as usable?
Is it possible to upgrade from Win8 32bit to Win8 x64bit
Is it possible to upgrade from Win8 32bit to Win8 x64bit or trick the PC into thinking its x64bit so I can install x64bit programs
Upgrade Win7 32Bit to Win8 64bit
I have windows 7 32 bit installed on 2 separate drives (dual boot). On one of the drives I want to install Windows 8, but want to use the 64 bit version to see if it runs a particular programme better taking advantage of more memory. According to MS upgrading using the Install Assistant or...
Driver Asus X401a - Win8 32bit
I have a Asus X401a. There are only drivers for Windows 7 32bit+64bit, Windows 8 64bit on Asus support page. Can I use one of them for Windows 8 32bit? Which one is the best?
Drivers & Hardware
