Severe echo during recording playback
    As a court reporter, I use a software (from Stenograph) which records to a .wav file as I write. I have such a severe echo during playback, which makes it impossible to even use this audiosync feature within my software. I am not very computer savvy, so I may need "dummy" type step-by-step instructions on changing the settings! Thank you! I should also mention that I am using the internal mic for recording. Thanks!
    By default (and not chageable) the PC's speakers are on all the time and thus if the speaker volume is not set to Zero (off) there can be feedback and echo.
    There are also some Sound Enhancements in many PC sound systems, such as echo, reverb, chorous that can be heard on any audio playback. If this is the case, check the Control Panel/Hardware and Sound for a sound control panel, such as the RealTek HD Audio Audio Manager (for systems with RealTek audio) as it has an option for Sound Effects such as Echo.
Severe Internet Lag when streaming video
Using my laptop, on both Wifi and Ethernet, there is a severe lag when streaming videos. I have no problem streaming videos on my desktop so it's not my ISP. See attached picture of the Ethernet performance - are those jumps normal? Is it possibly related to the fact that I'm always using 40%...
Network & Sharing
messed up audio playback/microphone with video recording
Don't know what I've done. Wanted to do a video recording using "camera" from my windows desktop. Got tinkering in my audio settings to eliminate background noise cause there was all this "whooshing" wind type sound during playback. Now I have NIL volume on video recordings I do with my computer's...
help with screen recording
whenever i try to record my screen,whatever software and settings i use,when i play back the video it shows on the top half of my screen and the rest is just black,either on windows media player or on the movie maker. heres a screenshot of what im talking about: 30384
Echo when using Line In (phone to pc) audio jack cable
Hello I have a audio jack cable i.e. and I want to listen to music on phone through computer speakers. It works, but..... In the sound control panel settings>recording tab>line in properties>Listen tab,...
Recording sound, playback sounds strange and distorted
severe slowdown/unresponsiveness
I'm typing this out on my xbox 360's chat pad so i apologize in advance for any horrendous spelling/grammer... its also 5 am.. so some latitude is appreciated.. ----------- ok, first things first. i tried one of the games that came pre-installed on the computer, a microsoft xbox branded...
Why doesnt the ceton echo work with windows 8?
Why don't wmc extenders work on windows 8? Are they working to fix this problem? I want to install windows 8 but this is stopping me from installing it
