Record Audio?
    Record Audio?
    I want to record audio from one of my workout videos to take with me on a trip. In the past, I had done this with audacity. However, when I open audacity now on Win 8, it says there is no sound device. Does anyone know of a way to just record the sound output from my machine? I.e. I would play the entire video, and just record the sound and take that with me.
    You need to have the "System Mixer" (may be called "Stereo Mix") selected as the default Recording Device.
    "What U Hear" Recording - Enable - Windows 7 Forums
    I'm not using my Win 8 system right now so I can't tell you exactly how to access the Sound Panel, but in the Recording Tab section if the System Mixer/Stereo Mix is show, enable it and set it as the default recording device. Audacity should be able to use this.
    If its not shown, RIGHT click in an blank area in the panel and then click to show both Disconnected and Disabled Devices. If the System Mixer/Stereo Mix is now shown, you can set it as the default recording device.
    This assumes you have the correct sound driver installed from either the PC vendor or motherboard vendor, as applicable. If you only have the generic basic function Windows installed HD Audio Codec that will not get you what you want. (Also please fill in the My System Specs - it helps us to try and help you).
    Last edited by Brink; 25 Jan 2013 at 11:46. Reason: added tutorial link for more info
Record Audio?
What software can you use to record both the internal and
What can you use to record both the internal sounds (hearable in earphones) and the external sounds (my voice) at the same time?
No record of update
A couple of hours ago, I restarted my Win 8 tablet. I got a shut down screen showing that an update was in progress. The Windows Update screen shows that my last update was installed at that time, but the Installed Updates list shows the last update was installed on 8/29, 5 days ago. What was...
Windows Updates & Activation
Can't Record Stereo Mix
I can't record stereo mix (things that I hear playing). I have an Asus N76VZ laptop with Realtek audio chip. Installed is the Asus N76 Realtek driver ( The thing is; this laptop has a specific sound system called Bang & Olufsen ICE Power. It has an external SonicMaster subwoofer which...
How to record webcam in stealth ?
I suspect someone is stealing from me. I would like to enable the You cam on both my Win 8 and Win 7 machines and turn the screen off when You cam is minimized and recording, but it will not do it even with the power set to do so at 1 minute as long as You cam is still running and minimized....
Drivers & Hardware
How to record both Stereo Mix and Microphone
As the topic above, I need help :cry: I using Headphone(include microphone) I had the latest Realtek Driver. My Laptop information : Windows 8 64bit 11685
Cannot record sound from websites
HELP! I have tried to record from a website with both Audacity and WavePad, but they can only record via the speakers, and of course this is not what I want - so how can I record directly??
Android malware uses your PC's own mic to record you
Read more at source: Android malware uses your PC's own mic to record you | Mobile - CNET News
Windows 8 News
