HELP!..can help anyone?
HeX
INDIA
after reinstalling win 8 there is still no sound all drivers devices are showing animation pls help no sound.. my motherboard GIGABYTE..sad pls help..PROBLEM in GAMING widout SOUND:cry:
    Windows 8 PRO
    AMD Phenom 2 X2 550
    GA M68MT-S2
    4096MB DDR3 DUAL CHANNELS
    ATI Radeon HD 5450
    Inbuilt/INTERNAL
    ACER
    1366x768
    500 GB WD(Western DIgital)
    V7
    Logitech USB mouse
    512 kb/s
    IBALL SPEAKERS but NO SOUND
I have a Gigabyte motherboard. When I installed Win 8, it installed a lot of drivers including the generic basic function HD Audio Codec for the sound. The sound worked but was not optimum. I then ran the Gigabyte install disc and installed all the drivers. This gave me all the correct drivers and everything worked.
Running the Gigabyte drivers would be the best first step.
If you can tell us the type of Gigabyte motherboard that you have then we can help you find the drivers you need.
For example, the brand of my motherboard is ASRock but my type is "z77".
Otherwise, you can search here (click the blue words) for your motherboard specific drivers.
    Windows 8.1 Professional 64-bit
    Custom
    Intel Core i5-3570k
    ASRock Intel Z77 Extreme4
    8GB
    NVIDIA GeForce GTX 670
    Hyper 212
Like Skulblaka has pointed out, the make and model number of your mobo is need for us to track down the needed drivers.
If you could put some more detail into your system specs area it would be a great benefit in giving you required help needed. Have a look at mine.
    Custom build
    AMD Phenom II X 4 965 BE
    Gigabyte GA-MA790X-DS4
    G-Skill 8 GB PC 8500
    AMD XFX HD Radeon 6790D
    Realtek HD onboard
    2l Samsung SyncMaster S20B300
    1600 X 900
    Seagate Barracuda 320 GB w/OS
    Cooler Master Hyper212 120mm
    Logitech G510
    Razor DeathAdder 3.5
installed the recommended driver still no sound
    Windows 8 PRO
    AMD Phenom 2 X2 550
    GA M68MT-S2
    ATI Radeon HD 5450
    Inbuilt/INTERNAL
    ACER
    1366x768
    V7
    Logitech USB mouse
    512 kb/s
What is the model of the Gigabyte motherboard? For example, my Gigabyte motherboard is "GAZ77X UD5H". That is what we need.
GA M68MT-S2
HelP..
    Windows 8 PRO
    AMD Phenom 2 X2 550
    GA M68MT-S2
    ATI Radeon HD 5450
    Inbuilt/INTERNAL
    ACER
    1366x768
    V7
    Logitech USB mouse
    512 kb/s
If you still have the Gigabyte supplied CD with all the drivers, run that and reinstall all the drivers. After reinstall, restart the PC and then check the sound. If there is still no sound on the rear GREEN speaker jack with the speakers, plug a headset into the rear GREEN speaker jack and see if you have audio. If there is no audio, check the Control Panel/Hardware and Sound/Sound panel Playback to make sure your "Speakers" are set as the default audio playback device. If something else is set, such as Digital or HDMI then you will not get any speaker or headset audio.
Here is the drivers for Windows 7 (there are no Win 8 drivers listed but the Win 7 work without problems) on the Gigabyte site:
GIGABYTE - Motherboard - Socket AM3+ - GA-M68MT-S2 (rev. 3.1)
Go here and scroll down and click "Show All" then you'll see "Audio". Click the first audio driver to download.
Also, I recommend you to install "Chipset" drivers.
    Custom
    Intel Core i5-3570k
    8GB
    Hyper 212
Have you tried installing the audio driver in windows 7 compatibility mode? Sometimes this will get it working.
    Custom build
    Realtek HD onboard
    1600 X 900
    Logitech G510
I've downloaded the driver and installed it in win 7 compability mode and even plugged my HEADPHONES but still no sound..:(
    Windows 8 PRO
    AMD Phenom 2 X2 550
    GA M68MT-S2
    ATI Radeon HD 5450
    Inbuilt/INTERNAL
    ACER
    1366x768
    V7
    Logitech USB mouse
    512 kb/s
Ive downloaded and installed driver in win 7 mode still no sound from speakers or HEADPHONE..:(
    Windows 8 PRO
    AMD Phenom 2 X2 550
    GA M68MT-S2
    ATI Radeon HD 5450
    Inbuilt/INTERNAL
    ACER
    1366x768
    V7
    Logitech USB mouse
    512 kb/s
I'm a little stumped, can you post a screenshot of this window? I'd like to see what it shows for you.
It can be found in Control Panel, Hardware and Sound.
    Custom
    Intel Core i5-3570k
    8GB
    Hyper 212
sc.png here it is
    Windows 8 PRO
    AMD Phenom 2 X2 550
    GA M68MT-S2
    ATI Radeon HD 5450
    Inbuilt/INTERNAL
    ACER
    1366x768
    V7
    Logitech USB mouse
    512 kb/s
It seems like everything is fine with the drivers. Your computer is showing nothing wrong. You should be getting sound. All I can think of right now is what fireberd has suggested.
Like fireberd pointed out, triple check that you've connected your audio device into the green input (I'm sure you already have). Try the front and back speaker jacks.
    Custom
    Intel Core i5-3570k
    8GB
    Hyper 212
NOSOUND in front panel too..:( can help?
    Windows 8 PRO
    AMD Phenom 2 X2 550
    GA M68MT-S2
    ATI Radeon HD 5450
    Inbuilt/INTERNAL
    ACER
    1366x768
    V7
    Logitech USB mouse
    512 kb/s
It's possible that the manufacturers haven't updated their drivers to run on Windows 8; but then they wouldn't install in the first place, I think. Honestly, I don't know how to help. I wouldn't contact GIGABYTE support and see what they say about this.
    Custom
    Intel Core i5-3570k
    8GB
    Hyper 212
ty...bro
but pls inform me if u can help..:)
im thinking of reinstalling windows 7..:(
    Windows 8 PRO
    AMD Phenom 2 X2 550
    GA M68MT-S2
    ATI Radeon HD 5450
    Inbuilt/INTERNAL
    ACER
    1366x768
    V7
    Logitech USB mouse
    512 kb/s
    Custom
    Intel Core i5-3570k
    8GB
    Hyper 212
